Hello From Ak
quick intro to everyone as the approriate thing to do on forums. my name is andrew i'm enlisted in the Coast Guard and currently stationed in Kodiak, Alaska. I've owned a total of 5 chevy's including a 1987 Chevette (for the younger ones thats nothin like a corvette). My only currently owned chevy is my K2500 a former alaska state trooper truck that has been in 2 front end accidents leaving the bumper looking like it got slapped in the face and missing one frame horn. she's a powerhouse though and has 105,000 miles and getting ready for a trip to North Carolina this summer where i'll make my residences for the next 4 years. Only crap i've done is paying to rhino line the bed and bottom panels, I herculined the interior and picked up a set of alloy wheels off a newer GMC truck. After that it's been a mostly maintainence free ride. Well that's it see you around the boards
-Andrew
chevyinalaska
