Hub Centric Wheel Adapters
the hammer
Does anyone know of a company or where to buy hub centric wheel adapters that do not have the press-in studs. I want to find wheel adapters that have the normal wheel lug studs in them that are pushed through from the back side (like they are normally on any car or truck). I do not want to buy any adapter that could potentially have the studs just pull right out of the adapter.
All of the spacers I have ever seen used a stud pressed in from the back side. There should be a machined in recess on the back side for them so that they sit flush. The FACT still remains that sdapters actually mean that you don't have the right wheels...
i agree with you, i do not want to get any adapters. my dillema is because of the lift kits i want to get for my truck. I wanted to get a lift kit that will not widen my front track width wider than OEM, which has pretty much left me with getting a pro-comp 6" lift. I wanted to get the Rancho 4" lift kit for my truck, but it widens the front track width almost 3". I was not able to find any 4" lift kit that keeps the track width the same front and back.
Wheelspacers.com will have exactly what you are looking for.
Went and had a look. Looks like well made stuff... but SHAZAM they are expensive!
HA Gomer Pile in the flesh! haha Those will get pricey. I emailed them for a custom quote and info on the construction. I would only need two, so lets see what it'll cost to make sure they are hubcentric. Will post when I get info.
