Gmt900 Tensioner Pulley
My tensioner pulley is making some nasty bearing noises (at idle) already with 13,000 miles. Anybody else have this problem or heard of it on the GMT900's?
I also have a ticking noise from the engine bay in high gear and light accelleration. I'm thinking this may be related.
I can't believe GM STILL has problems with these. Been an issue for like 20 freakin' years now. Not a big one...But every GM truck I've had since '89 on has had pulley bearing issues.
If you're the handy type, go look up a bearing dealer in your local area. You can pick up new, higher-quality bearings and press them in yourself for a fraction of the cost of a new pulley. Usually less than $10.
I can get a replacement AC DELCO for $17.60 shipped. I would rather do it myself then send it to a shop. But if it's common, I should prob. find a different brand. My S-10 Blazer did the same thing.
Are you talking the spring loaded tensioner pulley or the idler pulley. if I am not mistaken, the tensioner pulley costs a lot more than $ 17 from gmpartsdirect.com. More like $ 70.
2 reasons: cheap bearings
bearings possibly pressed wrong into the pulley
The tensioner pulley, not the idler pulley thats next to the alternator. $70 for just the pulley? Or the whole tensioner? I found just the pulley (P/N: 38009) for $14.24 and the tensioner with pulley (P/N: 38158) for $45.79 on RockAuto.com both are AC Delco.
I'm at work so can't get my warranty paperwork but does anybody know if I were to change the pulley myself if it would do anything to my warranty?
if you use a genuine GM identical part, there is no way anybody will know.
Yup....... I sell them like hot cakes........
Jbo
I can't imagine they would be able to tell or be able to kill any warranty for replacing a bearing in a pulley.
Nope. People are overly paranoid about GM voiding their warranties as far as I'm concerned.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
