Exhaust Tail Pipe Question
I'm changing the muffler on my truck (Corsa sport or Magnaflow) and was wondering if anybody has tucked (hidden) their tail pipe under the box and faced it down/outwards at the end of the box without the tail pipe being visible or exposed. I'm trying to go for a clean look and am wondering if its possible or if anybody has done this before???
Pics or opinions greatly appreciated...thanks
I know Matt_ and I are running the clean look. We cut our resonator off above the rear axle in such a way that the exhaust flows down towards the ground. I just did mine yesterday so I don't have a historical track record to go off of yet. Matt_ did his a while ago and still says he has not had any issues. My only concern is that the exhaust will start to damage the bottom on the bed or the spare tire since it is exhausting right by it.
Your absolute right. The hot exhaust combined with the high volume of condensation will accelerate corrosion (rust) underneath the truck.
i dont have this setup on my current truck, but I didn on my previous one for about 2 1/2 years before I sold it and never had any issues, it was a turn down right behind the cab.
I had a corsa muffler put on and I had the muffler shop custom bend a tail pipe for me. It stays up closer to the body and turns down at about a 45 degree angle right at the rear bumper. You cannot see it at all ( unless you're 3ft tall you'd probably see it).
To answer your question: Yes, it can be done.
I love the way my magnaflow 14" sounds. I had it mounted on the factory pipe, and had a nice SS tip lying around. No drone, and sounds great. I wouldn't think that there would be too much of a problem cutting off the pipe, I would have a turn down installed to direct the majority of the exhaust to the ground.
Here is my setup, 40 series Flowmaster with full 3inch pipe tucked just a little bit with no tip.
Off topic but how did you get your center cap bowties black?
Mine runs from the magnaflow and along the frame rails behind the rear axle. It is turned down 45 degrees to spit out the exhaust toward the ground. You can't see it, you can only hear it.
thanks alot everyone, especially elcompaLalo and 700 sportsman for the great closeup pics! I was a little concerned about moisture building up under the box and forming rust, but i think a guy would be safe if it was routed to near the back and pointed outwards especiallly like elcompaLalo's.
Great vid krobocop...i'm also considering that option, but i'm worried that the tips would get sandblasted over time as i do hit the gravel roads a fair amount.
I think i'm sold on the clean hidden exhaust look...
thanks again. This site rocks!
G
Do you have any pics you could share with me? thanks
Here are some pics and a video.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
