Gmt 900 Mirror ?
I'm having one on the mirrors replaced on my 2007 Silverado 1500 LTZ under warranty and the
dealer is telling me they have to paint match it. Is this correct?? Can you not just swap out the covers?
The thought of them painting anything makes me gringe... :lol:
Thanks
They can try and remove your original one,BUT....theres a good chance they will end up breaking one of the plastic tabs that hold it in place.
Strange about GM mirrors. Usually mirrors are available in the car/truck body color from most manufacturers.
Not from GM Pete,They are all "paint-to-match"
fiddyguru, do not worry about them painting the mirror. I have painted a mirror on a vehicle before with a can of spray paint and it came out great - a perfect match and nobody could ever tell the difference. I buffed it with a polishing compound after it dried.
Any average body shop should be able to do a good job painting a mirror. If they cannot paint a mirror, they cannot paint anything.
+1. I've had a couple things painted and the color match was perfect and have remained looking good.
actually ms3dale some gm parts are available already painted. ive ordered a couple dash bezels and door handles that come already matched to the paint code.
Yes,A lot of interior pieces are available painted,along with some door handles for older vehicles,as well as tailgate bezels for the GMT800 trucks,But not mirrors,mirrors have never been available already painted.
personally, if it was factory painted mirror when I bought, they would have to replace it with another painted mirror. They need to send it to the body shop to be painted. If they refuse flip to the back of the owner's manual and call GM's Customer Service and complain up the ladder until it's fixed right. They owe you a part that is a suitable replacement, one that doesn't match the vehicle is not suitable.
Any dealer would definitely paint an item if need be,We do it all the time here,The OP's concern was the quality of work the dealership would do.
Well, IF they know what they are doing, it is easy to get the cover off. Then just snap it on the new mirror. I have done it on several trucks. But if you get some new guy that does not know the trick to babying these covers off, he will break the tabs. Then you gotta paint it.
You just can't go at it with a hammer and prybar. You got to be gentle.
C
    mark2
    mark2
  • Who's Online   7 Members, 0 Anonymous, 605 Guests (See full list)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
