20x10?
brianp25
i found the wheel i want, its a rbp 93r black with chrome inserts, but it comes in 20x10.
i read that i should stay away from that size? also can anyonce recomnd a wheel that is similar to these?
Are you lifting the truck? What size tires do you want to run?
And is your 2007 the new body style (GMT900) or the classic (GMT800)?
The new trucks have a really hard time fitting wider wheels/tires without some form of trimming.
Those are a great looking wheel but man they are high dollar! Running them will depend greatly on the amount of lift and the tire size.
u guys know of a similiar wheel in a better size?
if there were... id probably have them on my truck because those wheels caught my eye last year too.
A different style, but these BMF Novakanes are an awesome looking wheel as well. I almost got these, but couldn't swing the $$$$... they were twice as much as the wheels i have now.
I am running 9.5" rims and would be very leery of going wider, as I am already pushing the limits. You need to make sure your backspacing and offset are perfect when running wider wheels, especially if you are planning on running larger tires.
man those wheels are bada$$, thanks
ordered these wheels today with 305/50/20 nitto terra grapplers, the guy said they wouldnt rub, but i just found a thread saying they do, guess ill just see how bad it is when they get here, thanks for every ones help
what is the clearance on the stock wheels? I have the fabtech 7" lift and want 20x10 (-12 offset), I'm not sure if they'll fit or not.
Versus the stock wheels (20x8.5 with 30mm offset) the 20x10's have 23mm more inner clearance and extend 61mm more out. I expect to have to do some trimming, but I want to make sure they will be close to fitting without too much modification.
These wheels come in 20x9 also, but I want to see if the wider rim will fit
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
