Loud Mettalic Clank
Hey guys, was wondering if anyone has this problem before.... after driving for a while and stopping at a stop light or shutting down the engine I hear a loud metallic clank coming from the passenger side of the engine compartment. It does not seem to matter if I have had the AC on or not. This noise usually occurs after sitting still for about a minute. My truck only recently started making this sound. The truck has almost 74000 miles, a 5.3L V8 with after market headers exhaust and intake kit. Any help that you can provide would be greatly appreciated since I just went out of warranty. By the way, headers, exhaust and intake havebeen on the truck almost three years now.
  • 3 weeks later...
Is there anyone that can post service Bulletin #030861002e? I would like to see if that has anything to with this problem... it now occurs while driving down the road ad can be felt in the floor boards. I have checked all of the heat shields and they are tight. This is getting worse.
I did have a complaint about 6 months ago that Chevy fixed... sounded like my right front tire assembly (meaning tire, coil springs, shock and control arms) was going to fall off of the truck. After a few days of troubleshooting the problem was fixed. When I asked what it was the service manager said "I have no idea... we just started taking your front end apart and put it back together."
Vehicle is now out of warranty but I will go back to them to have this problem looked at... although it will of course cost some outrageous amount of money because it will be found un-related to the original problem.
Only other thing i can think of is maybe the Catalytic converter on that side is going bad. Any suggestions you may have would be greatly appreciated. Thanks for your time.
I would put my money on the heat shields (from the temperature increase/decrease). My last few vehicles have done this after stopping. Is a metal pinging noise?
Yes it is. It happens while driving down the road, stopped at stop lights and after turning off the engine. My son claims he can feel it in the floor board on the passenger side... sounds like if is coming from the engine compartment area on the passenger side... a pistol shot would be a more accurate description of the sound.
Sounds a bit rough for just a heat shield. Have a dealership at least rule out the cats - they are under a longer-term warranty.
Maybe a Ford that got sucked up the tailpipe trying to get back out. :D
Maybe...
Going to take it in to the dealer tomorrow and let them look at it. Maybe it is something that wont cost me an arm, leg and my first born.
I am thinking the cat is going myself. I iwll post updates after visit to dealer in the morning.
After much anguish and gnashing of teeth, the problem appears to have been resolved. In this instance could have been any of several thing wrong... flange bolts on y-pipe loose and the crossmember bolts checked. thanks for all of your ideas.
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
    • I have a trailer lights checker I plugged into the 7 way connector in the bed of my truck that has the 5th wheel/gooseneck hitch. It gave the camera side view with the turn signal on just like having a trailer connected but it disabled the rear bumper sensors. I would rather have the rear sensors working.
    • You are winning more than battles. You're winning the war!  Nice.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
