A Few Sierra And Silvy Questions
Hello All, I have few questions for you guys...
1) Did Chevy make a quadsteer Silvy? The reason I ask is that I passed one the other day and it had an unusually wide rear axle. It also had the half dually style fenders with marker lights on them and the roof of the cab. I never knew Chevy had that option.
2) Also on a totally different truck I saw the old fiber glass/composite truck bed from a few years back. Was this a flop in the option department like quadsteer?
3) Last one is in my new 09 Sierras console. What the heck goes in the wasted space circled in red? I would rather of had another pocket like on the other side.
Yes they did make a quadrasteer, and it really helped with the turning radius of the truck...wasn't much of a seller though, as most of them were really high dollar trucks...and quite frankly, having a tight turning radius just isn't on the high end of owners priorities unless its just a city mobile...
The rear fenders had a noticeable bulge in them.. 04-05ish was the quadrasteer era if i remember correctly
1. As noted before,Yes,Chevy also made the Quadrasteer,The Q-steer trucks were produced from'02 to '05.
2. Yes,The "Pro-Tech" composite bed was available from '02 to '04,Our service director at the dealership worked for GM at the time when that option came out,He worked in the R&D dept. and oversaw some of the testing and development of it,It was a flop because it was expensive for GM to produce,He said it was too costly for GM to keep producing it for the price they were selling it for,it was also a repair nightmare if it got damaged due to collision,there were also environmental issues with the composite materials used.
3.That spot is for a coin holder....give me a few minutes and I'll get ya' a part number for one,I have no idea why GM didn't provide one in all trucks from the factory.
Rich, does GM even offer a replacement composite bed for those trucks that originally came with it? If yes, what is the cost? Just curious.
If I am not mistaken, 2010 Toyota Tacoma also uses a composite bed.
The Tacoma's have had composite beds for a few years now. I am thinking since 2007 but it could have been longer.
Part number for a coin holder is 12381882
Nope,Been discontinued,Theres a note in the catalog that the customer is to use a metal one for replacement,Most of the individual parts that were available also have been discontinued.
Yep,A guy at work has one.
Yep, one of the best parts of my Tacoma, studs on my sled cant even mark it!
I can't find one on ebay?? Also any chance of what it looks like i have that wasted space in mine and have change floating all over in the truck it is annoying that they don't have that on all of them!!!
Even with composite that thing flops around like it does? wow.
Coin holder??? What are you guys? Scrooge! It's there to hold a tube of Chapstick. Seriously, it fits perfect and it's what sits in mine... :D
I hate to say this, but me too.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
