Fuel Pump Not Getting Power
Ok, so I would just tow it to the dealer but I'm literally out of money. Put a brand new fuel pump on, still no buzz sound when key on, no start. Swapped relay from another one under the hood that is good, still no start. Please help. Truck turns over, just doesn't fire.
2002 Silverado 5.3
The best thing to do is check to see if power is getting to the feul pump with either a voltage tester or a light tester. Then trace back till you find the prolblem. Also check the ignition switch.
Check the ground. When I replaced mine, there was a ground strap attached to the frame next to the tank that was corroded. Removed the screw, scuffed up the frame and reattached it and it solved my problem. Don't know if this will help but I thought I'd put in my two cents.
Dave
Like others have said, check the fuses. If the computer fuse is not working, then the fuel pump will not get a signal to work. Also, remove the relay, and check for power. The relay will usually tell you what terminal has power. If all looks good, then jump the terminals with a pair of pliers, and see if that works. If it works, then the computer is probably not sending the signal to the relay.
    HWN808
    HWN808
  • Who's Online   6 Members, 0 Anonymous, 1,019 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
