Finally A K&n Air Filter For 2009's And 2010's
For those of you that have wanted a K&N Air Filter for your 2009 or 2010 GM, it has finally been created to deal with that pesky MAF sensor connection. Here is the info from the website and the link.
http://www.knfilters.com/search/product.aspx?Prod=63-3070
A sister product to our 57 Series FIPK, our 63 Series AirCharger® Intake Kits are guaranteed to increase horsepower and come with a Million Mile Limited Warranty. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction as they smooth and straighten air flow. This allows your vehicle's engine to inhale a larger amount of air than the OEM air filter assembly. More air means more usable power and acceleration throughout the engine's RPM range. The filters on these kits are washable and reusable. Most of our intake kits are relatively easy to install using tools commonly available (see installation instructions). 63 Series Intakes are street legal in most states. They are not legal for use in California and other states adopting California emission standards.
Part 63-3070 Product Specifications
Product Style: 63 Series Aircharger Kits
Estimated Horsepower Gain: 16.59 HP @ 5342 RPM
Replacement Filter: RF-1042
CARB Exempt: No
TUV Approved (Europe): No
Weight: 13.3 lb (6 kg)
Product Box Length: 22.25 in (565 mm)
Product Box Width: 14.25 in (362 mm)
Product Box Height: 12.5 in (318 mm)
Listed at $360
Click this link to ensure it will fit your vehicle
http://www.knfilters.com/search/applicatio...px?Prod=63-3070
So would this be worth it? or should I just go with the KN drop in?
Notice on their dyno chart, you really don't see any increase in horsepower until you are above 4000rpm. So, it makes sense that day-to-day driving you won't feel a bit of difference, but maybe for that occasional stoplight race you'll feel just a small amount of added power.
For the money, I don't think it looks all that great. I'd lean towards the Volant or the GMPP.....
Stock air box is more than adequate! IMO
I just want the tube.
i just called K&N the tube will be avail for sale. she said to call back in a few weeks.
Sweet. That might be the route I go
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
