I keep my owners manual in the glove box just for instances just like this. :)
If you have keyless entry then hold lock and unlock on the remote at the same time for like 5 seconds or until the horn beeps. Then starting at drivers front let air out until you hear the horn beep then go to the passenger front and release air until the horn beeps, then the passenger rear, then the drivers rear.
Each TPMS sensor has a unique identification code.
Any time you rotate your vehicle's tires or replace one
or more of the TPMS sensors, the identification codes
will need to be matched to the new tire/wheel position.
The sensors are matched to the tire/wheel positions in
the following order: driver side front tire, passenger side
front tire, passenger side rear tire, and driver side rear
tire using a TPMS diagnostic tool. See your dealer for
service.
The TPMS sensors can also be matched to each tire/
wheel position by increasing or decreasing the tire's air
pressure. If increasing the tire's air pressure, do not
exceed the maximum inflation pressure indicated on the
tire's sidewall.
To decrease air-pressure out of a tire you can use the
pointed end of the valve cap, a pencil-style air pressure
gauge, or a key.
You have two minutes to match the first tire/wheel
position, and five minutes overall to match all four tire/
wheel positions. If it takes longer than two minutes, to
match the first tire and wheel, or more than five minutes
to match all four tire and wheel positions the matching
process stops and you need to start over.
The TPMS sensor matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the
engine off.
3. Press the Remote Keyless Entry (RKE)
transmitter's LOCK and UNLOCK buttons at the
same time for approximately five seconds. The
horn sounds twice to signal the receiver is in
relearn mode and TIRE LEARNING ACTIVE
message displays on the DIC screen.
If your vehicle does not have RKE, press the
Driver Information Center (DIC) vehicle information
button until the PRESS V TO RELEARN TIRE
POSITIONS message displays. The horn sounds
twice to signal the receiver is in relearn mode and
TIRE LEARNING ACTIVE message displays on
the DIC screen.
If your vehicle does not have RKE or DIC buttons,
press the trip odometer reset stem located on the
instrument panel cluster until the PRESS V TO
RELEARN TIRE POSITIONS message displays.
The horn sounds twice to signal the receiver is in
4. Start with the driver side front tire.
5. Remove the valve cap from the valve cap stem.
Activate the TPMS sensor by increasing or
decreasing the tire's air pressure for five seconds,
or until a horn chirp sounds. The horn chirp, which
may take up to 30 seconds to sound, confirms that
the sensor identification code has been matched to
this tire and wheel position.
6. Proceed to the passenger side front tire, and
repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat
8. Proceed to the driver side rear tire, and repeat the
procedure in Step 5. The horn sounds two times to
indicate the sensor identification code has been
matched to the driver side rear tire, and that the
TPMS sensor matching process is no longer
active. The TIRE LEARNING ACTIVE message on
the DIC display screen goes off.
9. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure
level as indicated on the Tire and Loading
Information label.
11. Put the valve caps back on the valve stems.
Edited by mato27
A total PITA!! :) GM should come up with a more user-friendly way of doing this. The trick is to let air out for the first 5 seconds and then wait 30 seconds for the horn to beep. It may take several attempts at getting all of your sensors reset.
Yeah, like pushing a reset button on the dash to relearn all positions at once.
it wouldnt be able to identify the sensor locations in that case. tpms systems that dont tell you the pressures at each tire have a single reset button.
honestly... its not that hard to do. ive reset mine numerous time for new tire/wheel combos and new rotations and ive never had it not work on the first try..... i really dont know how much easier they can make it......
I have never been able to get the air pressure method to work.
My mom's Jeep doesn't need to be relearned, there are receivers at each wheel well that pick up the individual sensors. A lot better system than the stupid thing we have.
I think it works great. I do the key fob thing and make a quick lap around DEFLATING each tire until I get the beep. Now that it has learned I make one more lap and adjust them to there correct PSI. Couldn't be easier IMO.
Ok, that's interesting info.
I didn't even realize that you had to do that......
I guess I need to make a journey to the garage and get-r-done....
I tried several times to get my '07 to relearn tire position. Took it to the dealer in in about less than a minute, the service rep had grabbed a hand held computer unit, pressed the Relearn Tire Position button, walked around and pointed the unit at the valve stems until the horn honked, and done. No charge. Don't know why I couldn't do it myself. Maybe I needed to try a few more times?
Z
I have tried many times to get mine to work. Never happened
Just rotated my tires yesterday, here are the steps I took
1) Got in the truck and set the parking brake.
2) Turned the key on, yes on and not running. Repeat, not the accessory position.
3) Pushed and held the lock and unlock buttons on the FOB until the horn beeped twice.
4) Stepped out and went to the driver's side front and using the end of a tire gauge deflated the front tire until the horn beeped.
5) Moved to passenger side front and repeated, then passenger rear and finally driver's rear. After the last tire it beeps twice.
6) Went back around and deflated or inflated accordingly.
One observation I did make, I have a 2500HD and tires are 80 rear and 60 front. The tires with 80 PSI deflated much faster and it took just a few seconds get a beep. The tires at 60 took MUCH longer to get the beep, so at the lower pressure of a 1500 I would think it would take even longer. Also you have a 2 minute limit per tire so that is why I think it much easier to deflate then to inflate as you can move around the truck faster.
Edited by Diesail
If you're having trouble getting it to work try running a large magnet across the sensor as you're letting air out. I do this on the Vette and don't even need to let any air out but I do on the truck. I have a friend's truck where I can just use the magnet, so I'm guessing there are differences in the TPMS that's making it easier for some than others... I got a big magnet from Harbor Freight for ~$5 that works great. An old speaker magnet would work well too.
I could never get mine to work and after A LOT of searching I found a service bulletin for certain types of valve stem type (rubber I think it was) letting air out causes a harmonic vibration so the sensor thinks it rolling instead of sending position information and that the programming tool was the only was to get them to register.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 656 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
