What Are These Rubber Bumpers Called
on my lower frame on the front of my truck and where do i get new ones for my 02? i noticed that the ones on there now are broken and cracked
Sounds like he is talking about the bump stops. You can replace them with a set of timbrens if you are looking to add some lift and better strength for the front end. Also will help level out the truck. You gain 1" lift with them.
yes its the bumpstops i dont think i need the timbrens i cant seem to find them on gmparts site,can anyone tell me were i can find them? thanks rick
So if you just want to replace with the same, have you tried local junk yards?
  • 1 year later...
Use part#15835667 for the Z71 suspension package. They are a poly like substance rather than the foam/rubber like stock bumpers. They look to last much longer and probably firm the ride up some. I tow a 12k 5th wheel often and the stock ones were a mess at 80k.
http://www.dieselplace.com/forum/showthrea...3573&page=3
Check the difference out. Simple job, about $15/each. Big improvement!
