Aftermarket Installation Troubles.
I recently removed my in dash monitor from an 07 sierra new body style. I am running into some issues getting my mono block amp running correctly once again with the the stock deck. I cant seem to find a proper remote wire to splice into, and cant seem to find the correct wiring diagram on the internet. I have tried several pink/white wires in the fuse box on the left panel of the dash, as well as several in the radio harness itself and have had no luck, amp continues to stay on after the power is off.
I also installed a LOC and seem to be having some minor noises, possibly mechanical or maybe wires picking up other signals I dont know, any help on the topics would be great.
Also I am selling the clarion touchscreen indash monitor prewired with a 06 and up gm harness, I have some body damage to repair and this is necessary. Email for pictures.
You're not going to find a remote turn on wire anywhere, everything is LAN based. The only place to pick up retained accessory power (same power schedule as the factory radio) is in a socket in the MBEC. Do a search for RAP, someone did a really good write up on using it but you can probably run without a relay since the rem turn on is just a relay inside the amp.
I figured sense the remote worked fine previously in between the in-dash harness and the HU that there would be some source for the amp turn on on the stock harness. So there is a possiblity with them MBEC...I dont know what or where that is, any help haha?
    KirbyCo
    KirbyCo
  • Who's Online   1 Member, 0 Anonymous, 1,273 Guests (See full list)
