Rad Leaking After Coolant Flush
whitefish
I'm in the process of changing the timing belt, idler, water pump on my 2005 Aveo. I figured since I was changing the water pump, might as well flush the cooling system.
Timing belt change went without a hitch. Cooling system is another story. About half way through the belt change, I noticed a leak from the rad. I first I thought it was coming from the stop cock, but I later learned it was coming from the rad (water dripping). When I refilled the colling system with 50/50 DexCool, the bottom three inches of the rad fins turned red from the DexCool and eventually I could see a leak spewing coolant in the rad (when the car was running). The rad doesn't leak when the car is not running.
For the flush, this is the procedure I followed:
- I used Prestone Super Flush and followed the instructions
- after using the Prestone and waiting for the system to cool, I did a modified system "rinse/flush" by hooking a garden hose up to the pickup line running to the pressurized remote surge tank. I dis-connected the return line the goes from the rad to the remote tank - this is where the system was discharged into a 5 gallon pail. I blocked off the other return line the ran from the manifold. I started the car and ran the flush until the water ran clear.
- I drained what I could from the system via the stop cock on the bottom of the rad - I closed the stop cock after the system drained.
- the motor and rad stayed empty over two nights while I worked on the timing belt, etc.
- nighttime temps hovered around freezing, but above freezing in the garage - I had water laying in a bucket and there was no ice forming.
So here are my theories:
1) Prestone Super Flush is not really compatible with aluminum components and rads and it "ate" my rad (unlikely).
2) Prestone Super Flush is really good at what it does and any "gunk" that was plugging leaks in the rad was washed away and the rad leaked.
3) Despite draining the rad and (hopefully) the block, water in the rad froze and burst some of the tubes that still has water in it. I doubt this, since there wasn't even a skim of ice on the water I had in the garage. Also, the thermometer I have in the garage never went below freezing.
4) I damage one of the fins that damaged a tube.
What do you guys think happened?
5) The car is a $6000 Korean import manufactured by Daewoo that used cheap components because it was(is) built to a price point.
I'm going to go with number 5. Anyway, it's off to the dealer for a new radiator.
GM puts stop leak from the factory in its vehicles. Did you replace it when you flushed?
Really? The GM DexCool literature I read specifically said not to add any additives to the coolant.
Even if I added stop leak, I don't think it would stop this size of leak (can actually see a stream of coolant coming from the rad at operating temp).
I agree about these cars being a POS. Spend nothing on the car and spend it all on parts. Never again.
Problem solved. There was a pinhole leak in the rad. Not sure how it got there, but its there. The new jobber rad I got was an exact replacement - drain plug and everything. Replacement went without a hitch.
Quick question - I have a little weeping around the inlet for transaxle oil cooler line (the one the bolts on, not the return). Is the washer a compression washer (i.e. use once and throw away)? If so, I guess I would need to replace.
Also, how much oil is in the oil cooler - just wondering how much I need to top up the oil in the transaxle.
Thanks again!
Thanks again!
pretty sure your right on the compression washer
and I believe it takes about 1 quart in the cooler, maybe a little more, 2 Quarts would definitely be enough. That trans doesn't have a dipstick either does it. If you over fill the trans slightly it doesn't make much difference in those cars.
Thanks Nytemare,
Yes, the tranny has a dipstick. Didn't look like there was a quart of oil in the cooler. Maybe most of it drained back into the transaxle???
The dipstick shows enough oil at cold - will have to test after warmed up. I'll take some ATF with me tomorrow on my commute (only 20 miles) just in case.
Thanks Nytemare,
Cool...at least you got a dipstick...that's one thing your "cheap POS Daewoo made Chevy" gave you over a real Chevy...
Those sealed for life trans-axles are the stupidest idea ever.
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
