Spent 4-1/2 Hours Detail The Paint
It freaking rained!!!! :cool:
I borrowed my friends Porter cable and various pads and polishers.
2 coats of the medium to coarse cutter
1 coat of fine swirrel remover
1 coat of wax, hand polished off.
The paint looked better than new at 10:30pm last night..
There was a small window for rain today.. but it was suppose to be later in the day. BUT NOOOOOOOOOOO ... it was raining when I got up. :lol:
Well, I was going to take a few photos this morning but now it hardly looks like I did anything.
It was night and day how it turned out.. I was VERY pleased with the results. It got all the winter abuse out and the paint looks awesome!.
But now it's all dirty again... :cool:
My life's a living hell!
Now the dang suns out! Just throwing salt in my wound.
This is on my wish list
http://www.autogeek.net/cyclo-polisher.html
I spent Friday hand washing, polishing, waxing my truck. Looks and feels better than it did new in Nov.
Sunday I washed my wifes tahoe and noticed it had alot of tar. Got that off and decided to polish and wax it. Looked good for a day and coming home yesterday it rained so it got dirty :cool: this morning looking at it there arent many water spots mostly they ran off :lol:
I thought that it only rained after I washed my truck! :cool:
BTW, your trucks look fairly new. Why are you starting with paint cutting agents instead of clay?
Look on the bright side. You aren't located in SC. I cleaned my truck yesterday morning (not as involved, wash/dry). By lunch it was covered with yellow pollen.
We're getting there. I'll have the same issue before to long.
Ok, all cleaned up... AGAIN....
I'll try and get some photo's tomorrow. Too busy tonight. :thumbs:
I had a guy tell me years ago that when you get done waxing you should spray it down with water to let the wax harden, I scratched my head and said ummm ok.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
