Lack Of Power.....still
I posted a while back about my 350 V8 seemingly getting starved for power. Since then i've replaced the plugs and wires (made a huge difference) It runs ALOT smoother and doesnt sputter as much anymore. But it still seems to lack the get up and go it should have. I can stand on the Brake and give it gas to the floor and it will only get up to about 1500RPM's and it can't pull throught the brake to save its life. Also you guys told me to put seafoam through it, I did that in the gas tank and in the intake, planning on doing ti in the oil when it gets close to changing time. Would it possibly have some kind of restrictor on it that wont let it get higher RPM's with the brake down? If you guys could shed some light on this I would appreciate it, thanks.
Can't comment on older model years, but I DO know that the newer ECMs have what's called a Torque Braking setting, which, when engaged (default), the engine will not exceed a nominal RPM if the brake pedal is displaced. That is part of the abuse prevention built in to the modern pooters.
Again, not sure what was going on in the mid-90s in terms if that, but on the newer trucks, that is by design. A custom tune can turn that off.
(Looking at your sig stuff and user stuff I think you are talking about a 95 model) Not sure what was in and out during that vintage.
I thought all vehicles had to prevent movement when the brake is fully depressed to prevent situations should the gas pedal sticks.
Are you talking riding the brake or full pedal to the floor brake? Every vehicle I've owned will only toss the revs up until the converter stalls and then holds there.
The old TBI trucks have none of the restriction upon restriction in the ECM's like the LS series engine equipped trucks do. Basically beyond a lazy fuel and timing curve, they do whatever 200 Hp and 300 lb ft can just like a carbed engine would.
Have you checked the timing on this truck? Fuel pressure? What about a compression test too while you are at it. Lack of engine power is usually fuel or timing related.
Has the truck ever pulled hard or has it been this way since you got a hold of it? Some of them unfortunately are just dogs.
it's your torque converter. stalls at 1500 rpm, and your not putting out enough power to over ride the breaks. if it is so inportent to brake your wheels louse, than put a 3000 stall converter in. that should do it.. :D
did you replace the fuel filter? A plugged exhaust will also act like that, it will drive fairly normal with normal throttle pressure, but die on heavy throttle/load.
Thanks guys, I will definitly investigate your input. My brother actually has a fuel filter for my truck I just havent gotten from him. But I do plan on getting it soon.
Have you tried to do the same "brake stand" in 1 and not D??
Try that and report back.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
