Factory Bluetooth Button Functions?
I've had my factory VCIM with Bluetooth in for a few weeks now. All is working well. But I only use one button and don't know if there are any other functions on my steering wheel for use when using bluetooth. Can anyone explain all the wheel button functions available?
Thanks
Chuck
Well as I'm sure you know, the "mute" button is also used to trigger the menu from which bluetooth functions are accessed. During a call, you can bring up the function menu by pressing the same button. If I remember right, this function allows you to "dial" your way through automated phone menus.
You can also use the "down arrow" button (used to select radio presets) to hang up a call, or to dismiss an incoming/ringing call to your voice mail.
That's about it.
Thanks
Chuck
Chuck, did come stock with bluetooth or you added the feature later, I am interested in bluetooth and wonder if I can add the factory feature.
Thanks
Thanks
Chuck
Thanks
its Possible, but GM has made it Nigh On IMPOSSIBLE to Add it. We have a few threads dedicated to Adding Bluetooth to your Truck!
