Bds Lifts, Which One Should I Get
hey im looking at getting a bds lift, either the 4 inch or 6 inch and there are two different kinds of each. according to the web site im on it says i can get a block kit or leaf springs. i no the leaf springs are more expensive but i was wondering if its worth the extra cash if anyone could help me out on this?
Usually people only buy leaf springs if they have money to burn, or their old springs are sagging. If the factory springs are in good shape just get blocks to save some cash.
i would go with the 6", most people that go with the 4" wind up wishing they went with the 6". i would also go with the leaf springs, as it will reduce axle wrap.
I would do 6" with blocks in the rear unless you plan on really really beating the hell out of it or doing heavy towing. then get springs
nope.. make sure u get a real 33 like a 33x12.50 tire.
just because a tire is measured in standard form (33x12.5 for example) doesnt mean it's "true" to that size. most run about at least a .5" small. and IMO a 33" will look small
I'd much rather see 35's on there instead of 33's. And def go with 6 inch. For such a small price difference I'd go with 6 inch over 4 inch.
ok i have an 09 silverado 5.3 will i have to do any gear reduction or something like that if i go 35 or will it be ok, i do a little bit of towing. I also want to keep my stock rims, i didnt read anywhere that you need aftermarket rims with ofset, is that correct?
and thanks so much for all the help
as for if you would have to re-gear it depends on your trans and stock gear ratio. do you have the 4spd or 6spd? what is your current gear ratio? bds's site doesn't say anything about being able to use stock wheels, i would call BDS just to be sure.
I have the fabtech lift, with 305/55/20s its a bigger lift, and 33 x 12s. Though I fully plan to run 35s when these are worn out, i have decided to just kill off the 33s. I have NEVER had one person ever give me anything but compliments on it. I am installing the 1.5" body lift when i put the 35s on just to maintain the gaps n clearance.
There are plenty of people on here running 6inch lifts PLUS 3 inch body lifts with 35s. No one ever says theirs looks small. Just sayin.
You might need some wheel adapters to give you extra backspace if you want to run the stock rims. Stock rims are a bad idea though. Really skinny and your tire will NOT sit as flat as with a wider 9 or 10" wheel.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
