  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
I'm currently in Ozark, AL. (retired Military). But have lived in West Lafayette, Klondike School area. and graduated in Versailles, IN.
  • 3 months later...
wheres everyone at around here. its dead!
Well I guess that I can post that I have now officially moved to Columbus, IN and started working. (Actually started at the end of Feb.) I am originally from Henderson, KY (right across from Evansville) and I went to school in Ohio. Seems like Indiana is well represented on this board.
Hey man I work at Cummins in Columbus. How about you?
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
