Failed State Inspection --argggg
I have a 2007 Sierra(GMT-900) with 86k on it and I just failed my state safety inspection because of LF HUB/BRG, EXCESS PLAY. Does this sound right? It was the dealership so they wanted $475+tax for the work which seems a little bit much. Is this a serious thing that I should address right away or try and get another station to pass me. My truck looks pretty dorky with the ghost buster rejection sticker in the middle of my windshield.
where are you located and what is that exactly? are they saying your left front hub is going out? if so I'd get that taken care of. Any shop that does front end work could do that which includes just about any auto repair shop and most tire shops.
I have a list at home of all the things covered under the 100,000mi warranty which I believe was standard on all the GMT-900 trucks. I am 99% positive that Hubs / Wheel barrings are on it and that they should be covered under that warranty.
I went out to my truck and got the manual with the 2007 Supplement to the Warranty and it is covered. Called the dealership and they are going to fix it tomorrow at 730. I just dont get why they would try and charge me for a warrantable repair. Stealers
The dealership probably gets more money when they charge you, as opposed to whatever GM agrees to pay for warranty work. Moral of the story, know whats under your warranty, and bicker when you have a warranty claim.
An ancient trick that they may have been pulling on you is the double ticket. IE, they write you up for the repair that you pay for and also write you up for the same job on a warranty repair. End result is that they get paid twice for the same work. Pretty sneaky.
Bearings are not covered under the 100k
just the 36K.
I'm not saying I agree with it....but its just axles to the hub engine and trans...and associated electronics under the Powertrain warranty.
Sorry dude...but 475 for a dealership to replace a bearing is pretty good...they not exactly cheap for your truck.
The Delco replacements for your truck are between 216 and 245 depending on 2 or 4wd....on rock auto...I'm sure the dealer will charge more than this...so they are quoting about 1.5hr labor...thats not bad man.
just the 36K.
Agreed.
If you have to replace one, why not do the other side at the same time? That's just me though, I wouldn't replace one side without doing the other. If it's not covered under warranty, I would do it myself and save some money, but once again, that's just me.
just the 36K.
Read the 2007 Supplement to the warranty. It is explicit. The dealership checked their list of covered parts and has agreed to do the work.
I agree if one is shot the other is probably not far away. I would push while its in the shop to have the other one checked real close. It will save you the headach of a return trip and make them all the $$ at once, a win / win.
just the 36K.
That's good to hear man....You don't see many bearings getting replaced under powertrain man...Good on you.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
