Wiring 2010 Ppv Tahoe
Looking for help with SEO 6J3,WX7,6J4,6J1 These are the wires that I have laying in front of my center console and I am looking to hook up my Black Magic Hella Fogs without going thru the fire wall using any of the available power from these wiring harnesses that I have available. THis may be a tricky one but I need some guidance. Thanks in advance! This is for a 2010 PPV Tahoe 2wd
Just curious, but how did you manage to get your hands on a brand new PPV Tahoe (assuming you're not a LEO)?
Not sure if you've already seen this or not, but GM Fleet and Commercial publishes this document about the PPV Tahoe:
http://www.gmfleet.com/pdf/Tahoe+sm.pdf
The last page describes the following:
6J3 WIRING - GRILLE LAMPS, SPEAKER
One 16 gauge wire to alternating signal flasher mounted to the right
hand closeout panel. Sixty inches of extra wire from flasher is coiled
under the instrument panel. Two 16 gauge wires are routed from flasher
to an area behind grille. Two 16 gauge speaker lead wires routed from
under the instrument panel to an area behind the grille. All 4 wires have
24 inches of extra wire in coil behind grille. Grille lamps and speaker
are not included.
6J4 WIRING - HORN/SIREN CIRCUIT
Two 16 gauge wires are connected to an in-line connector in the horn
circuit of the instrument panel harness under the instrument panel. The
end of this harness extension is terminated with an in-line connector in a
60 inch coil under the instrument panel. Connection to customer switching
permits operation of the horn or siren with the horn button.
WX7 WIRING - FRONT SPEAKERS
Approximately 60 inches of auxiliary speaker wire is run from the doormounted
speakers and coiled under the center of the instrument panel.
6J7 EXTERIOR LAMP EMERGENCY FLASHING SYSTEM, HEADLAMPS, TAIL LAMPS AND BACK-UP LIGHTS
SEO 6J7 provides a high-beam headlamps flashing module, rear lamps
flashing and control wire for a customer-furnished switch to turn the
module on or off. The flasher control wire is coiled under the center of
the instrument panel. This control lead may be combined with the interior
wiring leads for SEO 6J3 when that option is ordered with SEO 6J7.
The headlamps flashing module is located below the passenger’s side
front headlamp and forward of the passenger’s side front wheel. The
module is connected to an inline connector in the forward lamp harness.
The headlamps flashing module is activated by the application of 12
volts to a dark green/red wire coiled in the passenger’s side footwell.
When activated, the driver’s and passenger’s side high-beam headlamps
and the high-beam instrument panel cluster light will flash alternately at
2.4 flashes per second.
When the headlamps flashing module is turned on, the module sends a
signal to the Body Control Module (BCM). The BCM alternately flashes
the stop lamps and backup lamps. Depressing the brake pedal will
override the stop lamp flashing and placing the transmission in reverse
will override the backup lamp flashing.
Activation of the headlamp and rearlamp flashing can be separated. Call
Kerr Industries at 905-725-6561 for instructions
During daylight conditions, the Daytime Running Lamps (DRL) are
automatically turned off whenever the headlamps flasher module is
activated. During nighttime conditions, the low-beam headlamps turn
on automatically while the high-beam headlamps flash. Turning on the
high-beam headlamps manually with the turn signal/multifunction lever
will override the flashing module and the high-beam headlamps will
operate continuously.
A 20 amp fuse protects the flasher module circuit. This fuse is located
in the underhood fuse block in the engine compartment on the driver’s
side of the vehicle. See “Fuses and Circuit Breakers” in the Service
and Appearance Care section of your Tahoe owner’s manual for more
information.
When it is dark outside, the tail lamps will turn on automatically. The
Center High-Mounted Stoplamp (CHMSL) will not flash and will operate
only when the regular brake pedal is pressed.
Note Wiring diagram is shown in Police Package Owner’s Manual Supplement (shipped in glove box).
The wiring diagrams are also available in the following PDF, starting on page 105 for the Tahoe:
http://www.gmfleet.com/pdf/2010_GM_Police_...cipal_Guide.pdf
Hopefully that gives you some idea of what you needed to know. You might also find the GM Upfitter electrical manual for C/K trucks of some use as well:
http://www.gmupfitter.com/publicat/2010_BB...Elec_1_7_D1.pdf
No actually I am an Aries............lol :) J/K I am retired leo and have vendor status along with being contracted by US Gov for a few things here and there. Also on the board of a rather large national police organization. Thanks for your help! this is much more than i was able to find on my own.
are not included.
information.
any pics? i kinda want to see the interior of a ppv...
I'm sure your local sheriff would be glad to show you the interior of a PPV; and there are a number of things you could do to convince him! :sigh:
Here are a couple official GM shots though:
No actually I am an Aries............lol :D J/K I am retired leo and have vendor status along with being contracted by US Gov for a few things here and there. Also on the board of a rather large national police organization. Thanks for your help! this is much more than i was able to find on my own.
Glad to help! Hopefully that gives you enough information to go on that you can make your lighting work.
You're lucky having access to that; probably also means you could order up a 2011 Caprice if you wanted one.... and I'm VERY jealous about that! :mad:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
