Tire Size Diffrence - 2007 Gmc Sierra
Peadog
Hi Guys
I have a 2007 GMC Sierra SLT, the tires on my truck that are stock are P275/55R20. A friend of mine has a set of P265/50R20 Dunlop Grantrex for me.
Will they fit my truck? also what is the pros and cons to going to this tire?
thanks
Paul
265/50/20 is 30.5x10.5
275/55/20 is 32x11
why would you want a shorter/thinner tire?
i see no pro's.... except maybe for 1/4 mile times.... sometime people like smaller tires for towing really heavy loads, but since they're P-rated you shouldnt be using them for loads that would matter anyway (in other words, for your trucks towing capabilities theres really no benefit to the smaller tire size... it'll handle the loads just as well with the 275s)
con's....
tires will look small
RPMs will be higher
275/55/20 is 32x11
con's....
RPMs will be higher
Matt- would you say a 285/65/20 is a good all terrain size for 33" tires on some factory 20's?
Are you planning on running any lift? As previously stated... that tire is a 34.5x11.22.
If you're only planning on running something like a 2" leveling kit, your best option is 275/60/20s. (33x11)
Edit: oh wait... you're the one that PM'd me..
Do what you said you were going to do in the PM!!! 3" body lift + 2" leveling kit.
.. then get some 305/55/20s and call it a day :uhoh:
Yes sir, I actually sent you the PM after I posted this. Not starting my new job until monday gives me way too much time to surf these forums.
But yes....305/55/20's will be what I'm going to do after talking with you about it.
  • 1 month later...
hey guys i have a 08 sierra denali i what to install a 1.5 or a 3in body lift due to the AWD complications with a suspentions lift but thats another topic. do you think i chould fit 285/65/20 on with a 1.5 lift. has any one acomplished this with leveling kit, trimming or a little body lift like i want
.. then get some 305/55/20s and call it a day :cheers:
