Woot.com Monkeys
http://shop.ebay.com/pringlescanmysteryman...from=&_ipg=
I just listed a bunch of woot monkeys if anyone is interested... Some may know what they are and most wont... but those that do know they are rare to get during the wootoff.... :lol:
If I didn't already have a bunch of 'em, I'd buy one from you. I had an original Woot Monkey and then at TechEd apparently everyone got on the screaming monkey bandwagon and I got three more. :lol:
They were recently acquired by Amazon. I always prefer to get my news from a
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
