Does your rear end slope?
Hi,
I recently purchased a 2002 Silverado 1500HD 4x4.  I just noticed that the right rear corner of the truck is about 3 inches higher than the left.  The dealer says that this is "normal."  I haven't checked any other trucks yet, but I was wondering if anyone else has seen this on their trucks.
I measured from the ground to the top of the tail gate on both the left and right sides.  The passenger side is higher.
I appreciate it I could get some feedback on how other people's trucks measure up.
Thanks,
Milt
Havent Checked mine but it doesnt look to be unlevel with the naked eye! The ZR2 Blazer I had before was a couple inches lower front and rear on the passenger side, so I took it to the dealer and they cranked the passenger side t-bar and it brought up the front and rear on the passenger side to make it level all around!
Evidently it's not uncommon for there to be a small difference - maybe 1" or less, but if it's really 3 inches off THAT'S not normal!  I'd take it back and talk in earnest w/ the service manager.
I agree with Greenrado.  I would express my doubts in the SAFETY of operating a vehicle with something "wrong" with the rear suspension.
My guess for the rear end slope is when they attached it to the semi they tightened it down to much.  I have heard this from a few people who had this problem their dealer told them thats what happened
Is this with a full or empty tank of fuel? Where is your tank located?
This does happen alot!!!!! When we got our ;95 we had to take it back for an alignment because it wore out the front tires in a few thousand mile, and the dealer said its where they cranked it down so hard on the truck!!!!!
Hi,
Thanks,
Milt
Milt, how does the front measure from side to side?
The left side can be an inch or so lower due to more weight on that side, but 3 inches is way too much.
If the front drivers side is also 3" lower than the pass they might try torqueing the torsion Bars, but that wouldnt help the back.
You may need new springs.
Thats what I thought too, but it does effect the back!!!!! My whole passenger side was lower on my ZR2 so they cranked the t-bar and it leveled it, the rear too!!!
This subject comes up from time to time. My observation since I got my 01 RC LB is that if your truck is not level , it leans left (driver side is low).
I noticed all weekend my truck leaned alot to the right.  Really drove me nuts.  What i did find out is i was on a SLIGHT (very slight) slope to the right.  I got freaked out until i parked on level ground and seen it sit level
In the Oct. issue of Populer Mechanics the same question was asked in the "Car Care" clinic.
They say to measure off the frame rails and not the bodywork (something which I've always suggested).
More importantly, they say that some manufacturers specify different rate left and right front springs.  (Or in the case of torsion bars, the right one could be cranked a little tighter).  A stiffer right front will cause the left rear to be lower.  The reason for this is to compensate for the camber or crown of the road so the truck won't pull to the right when going down the road.
