New From Az
kmv03
post-76819-1279955684_thumb.jpgNew guy, have an 07 1500 reg cab short bed. 4.8L which I plan on upsizing to anywhere from a 5.3 to a 5.8 depending on what crank/bore I decide on. 3/6 drop soon to come, once the Arizona sun cools down enough to work on her again. Any suggestions on rotating assemblies or motor combos is appreciated. She's sittin on 24's so im not lookin for much torque since there wont be any traction
