Satan In Mississippi?
sab316
So I think Satan has set up shop here in Mississippi. Its been down right ridiculously hot. I've been working outside my whole life (11 years, I'm 21 now) I'm working around 60-70 hours a week. Well this week is like 100-105 with humidity about 85% and heat indexes around 115-120. Actually had heat index of 122 the other day here. Its almost hard to breath outside, you're just baking! Even our Mexican workers are saying its some of the hottest temperatures they've ever worked in.
There is no end in sight either... Small chance of rain Thursday then Saturday-Tuesday all back into the 100's.
I know there are other people on here from the deep south. Who can't wait for winter and frost?
It's been brutal, even up here lately. Just kills me how the office jockeys whine about the weather, when they are only actually outside for about 15 minutes a day....and that's if they aren't in an enclosed parking ramp. ;)
Stay safe out there.
It's horrible here, also. The sweat just pours off your head. The humidity is horrible. You know what they say, "The Devil went down to Georgia."
Did he find anything of yours to steal??
It has been brutal. I got out in the yard at the crack of dawn on Saturday and got most of my work done before 10am. With the humidity, it was already getting freakin' hot. So having nothing to do outside in 100°+ weather, I decided to go to the range. Apparently, that was a pretty popular idea b/c it was full! I've never gone there and seen it full unless they had a big concealed carry class shooting.
Oh well, waited around and BS'd for thirty minutes and finally got a lane. After leaving that ice-box and going outside to leave, it was actually painful.
I got in my truck yesterday and it said the outside temp was 115... On the way home it got down to a brisk 105
Well there has been like 5 people die in Memphis this year from high temps. Then a small girl around my town went down a metal slide and got 3rd degree burns.
Its just ridiculously hot. I've never seen it this bad. Had the worst winter in like 100 years this winter. Got into the single digits in Mississippi which is unheard of and now I'm baking in 120 degree heat indexes.
I'm ready for winter!!!!!! Talk about working outside.......you should try working in a steel mill. 30-45 minutes doing something and you're soaking wet.
I can imagine man. We start work at 7 a.m. by 7:15 a.m. I have soaking wet underwear. And having the swamp crotch all day isn't a pleasant things. Can you say chaffing?
Are there a lot of places over your way breaking records? This heat sucks man, I wouldn't mind January weather all year round.
Yeah everywhere is. The low last night was 83 here in my town and its been like that all week... and no end in sight. I'm so ready for frost its crazy :lol:
Well, my soul rotted away years ago, so no, there was nothing left of me to steal.  :lol:
As of 4:56 AM this morning the temperature is 87 degrees. That's crazy for a low haha
It's that "global warming" crap, although I think the thermostat has slipped past "warm" and gone to "hot".
Got a really good deal on a new Columbia coat back in April and can't wait to actually wear it for warmth, if that ever happens again.
Here's something I hope makes you feel a little cooler:
You haven't heard of The Wedge? Fold a paper towel in half and then in half again. I'll let you figure out the rest..
:rolleyes:
man ive never been down southern states but ive been in some hot weather for me anyways, coveralls all day welding in 30C thats hot enough for me....summer is super short in northern alberta, only have a few more weeks of super hot weather then the leaves will start turning.
    • The part # is 84520447, mine does not have the cooled seats but I'm willing to possibly change the cover and foam if needed.   I tried that site and a few others,  added to cart and then paid. About an hout later I received a refund stating it has been discontinued.
    • Thought I would add to what Bruce answered, not only do the HD models use the torsion bar system, there are I believe 5 different torsion bar spring ratings that are all physically interchangeable with all the HD trucks going from a two wheel drive 2500 all the way up to the duramax or a gas engine truck with a snow plow prep package front end weight capacity that use the maximum sized torsion bar. It starts from a 4400 lb rated set in 400 lb increments up to 6000 lb. If one wants to fine tune the ride for a certain truck application they can swap out the torsion bars.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
