What A Way To Quit Your Job!
bb123
I guess he was fed up. lol
____________________________________________
JetBlue attendant slides down emergency chute after fight with passenger
Police arrested a JetBlue flight attendant today at New York's John F. Kennedy International Airport after he got into a verbal altercation with a passenger and then fled the scene by sliding down the plane's emergency evacuation chute.
It all happened as the plane pulled into the gate at JFK after what had been a routine flight from Pittsburgh. But shortly after landing, a passenger stood up as the plane was taxiing to the gate and began removing his bags from the overhead bin According to the Wall Street Journal's Sean Gardiner, the flight attendant, identified as Steven Slater, asked the passenger to return to his seat.
A "heated" exchange ensued, which culminated in Slater walking to the rear of the plane, where he grabbed the intercom. "To the passenger who called me a motherf***er, f*** you!" Slater yelled, passengers tell the New York Daily News. "I've been in the business 28 years. I've had it. That's it." He activated the emergency chute and slid away.
Slater then walked along the jetway into the terminal, where he took a shuttle to the employee parking lot. Observers watched as he ripped off his JetBlue tie and threw it to the ground. Slater got into his vehicle and drove to his home in Queens. According to the New York Times' Ray Rivera, he was arrested shortly afterward and faces charges of criminal mischief and trespassing.
A source tells WNBC that Slater was "having a bad day."
Local news is reporting he asked the passenger to sit down, and she ignored him, and pulled her bag out of the carry on bin, hitting him in the head. He then asked if she was going to apologize, and she said "nope"!
I've never worked in a "service" type job, but have seen plenty of people treat waiters, hotel employees and flight attendants like crap. If he stopped at the PA announcement, he may have been able to keep his job without charges, but I think the grabbing a beer and hitting the emergency exit chute might have ruined chances for a return to work!
Today, we salute you, Mr. Tired-Of-Your-S@#t Flight Attendant. Everybody has thought about quitting their job in style, but you raised the bar for us all. When a customer starts giving you s@#t, you give it right back... over the intercom... at full volume. And when the time comes to leave, you don't just calmly walk out the door. No. You ask yourself, "What would Batman do?" and deploy the emergency slide and make your getaway like a Navy Seal. All while stealing beer.
So crack open an ice cold Bud Light, Mr. Tired-Of-Your-S@#t Flight Attendant, because it's Monday. F@#k it.
I hear it on the radio now.
LOL
No, Olds and Pontiac went out with a "thud" as in GM slamming the door shut on those 2 brands.
Talk about going out with a bang.
like Oldsmobile did in 2004!
I thought Olds went out with a Bang with the Final 500.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
