Xm Radio - Reception Issues!
So i bought this new Sierra, and i have the 90 day trial of XM Radio. I have had Sirius for @ 3 yrs with a Sportster Radio and the reception is very good. But with this Factory installed XM radio i lose reception if a goose flies over my truck.
I was just wondering if any other members have experienced these issues. I have contacted XM 4 times and finally got through and they apparently sent a signal to the radio to attempt to improve the service. But it did not help at all.
may depend were you are located, up north here xm was always bad like that, just driving by a building it cuts out, i`ve stuck with sirius, much better reception. :D
could be something your dealer may be able to fix, maybe a defective attenna....:rolleyes:
The people at XM radio keep calling me wanting me to renew my subscription (my 90 day trial subscription ended this past week). I asked them if they could do anything about losing the reception and they said that was "a minor inconvenience" with satellite radio (much like satellite television). Any time I drove under an overpass, I would lose reception...drive under high voltage power lines, I would lose reception...pull in my driveway, I would lose reception (there are a bunch of overhanging tree limbs over my driveway though). Needless to say, I didn't re-up when it expired.
We have the same problem. I have a Sirius Stratus 4 in my truck and rarely lose a signal. I even keep a signal in the tunnel on I-10 through downtown Phoenix. My wife's Patriot has the built in Sat radio and it loses a signal every time it goes under an overpass. I think the "teardrop" magnetic antenna may be superior to the factory installed one.
BTW -- "goose flies over" :thumbs:
BC
I have an 08 and replaced my entire system with an after-market Pioneer deck / nav and Sirius tuner. I [pulled the OEM XM tuner and reused the OEM antenna for the Sirius and now have no reception problems. I'm not sure what the difference is because XM reception sucked and Sirius is great using the same antenna.
Yea I have been doing more and more research and apparently the XM satelites are lower in the horizon and Sirius are higher. Who know I want Sirius and I have been looking at this product and I still need to give them a call and see if it is compatible.
http://www.tss-radio.com/products/gm-sirius-connect-sirgm1
I think that it is compatible but honestly instead of that I would go with the Sporster 5. I put one in my Wife's car and if you take your time on the install they look good, the colors can be changed to match most any interior and it has a nice big screen to display info.
Or go crazy like I did and install an entirely new deck w/iPod and Sirius.
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
