Stobing headlights
Does anyone know how to get the stobing light effect from your head lights.
I would like my headlights to strobe alternately when I either use my hazards or turn on a toggle switch.
MTmace
Strobe and wig-wag are two different systems.  Strobe involves drilling and installing seperate lights, switches and power supplies.
Wig-wag can be added to existing lights somewhat easier.
Check out fire/ems supply companies and catalogs for specifics.
For the wig-wags, I wired them to my highbeams.  Pull back the accesory stick and they come on.  Seperate on/off switch for normal usage of the highbeams.
Strobes can be mounted in the grill area or wired to the parking lights.  It's easier to get the kit that drills into the parking/corner lights with seperate bulbs.
BTW, like the others said, check your local laws.  I do rescue diving so I have them on my truck.  Don't really need them but they look cool but I can only run white/amber in the front, no reds or blues.
If I'm not mistaken, our headlights already have a hole in them for a strobe bulb (covered with a blue sticker).
Anyone that can verify this?  I've been kicking around the idea of some strobes perhaps.
At my work we installed a kit call "Show Me" it comes with all bulbs, wires, and transformer box and it will allow the bulbs to strobe 3 or 4 different pattrens.
Click here
HIGH-BEAM AND WARNING LIGHT FLASHER
Converts high beams or warning lights and handles up to 20 amps (10 amps per side). Solid-state circuitry maintains constant flash pattern. Includes flasher, terminals, wiring, switch, instructions. For 12V systems.
High-beam and Warning Light Flasher Conversion Kit
   Each
   89ZX0348X
   $59.99
