Rer Gears
ive been looking around. i want to change the gears out back. not sure what i have but i know its not what i want. im thinking a 3.73 or a 4.10. but i want a locker
any help? i need to know what people are running and where to look
is the rear end a 10 bolt or a 12 bolt? what size? i found a ring and pinion set. its like $168.
Check your RPO codes in the glove box to find out which gears you have now.
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
G80 Rear Axle: Positraction
HC4 Rear Axle: 4.56 Ratio
HC7 Rear Axle: 5.13 Ratio
G80 Rear Axle: limited slip-cars, heavy duty locking-trucks
Fixed that for you...
what do you mean?
Your differential is a ten bolt. There are 10 bolts in the cover.. with an 8.6 ring gear...and 3.42 is close to 3.73. You would not notice the change as much as going to a 4.10.
also what size? im seeing 7.5 and 8.5
what do you mean?
so the name is the number of bolts on the pumpkin... and so i need an 8.6 inch ring gear.
well i wouldnt be installing a locker right away because i dont believe i have one. what makes it so special that i cant shadetree it
a lot of the sites say 8.50/8.625
