Clunk When I Turn Off The Truck
Hi guys, I just noticed this morning and when I got home from work this morning. When I park the truck, and shift into P, and then turn the truck off, it sort of does a clunk. I am curious if this could be the slip yoke that needs greasing like some of the posts I've read, or if it could be something else? The transmission seems to shift fine, and doesn't clunk when going into gear or on shifts. The truck is a 2007 NBS Z71 Ext. Cab. Thanks for your input!
Doesn't fit the common slip yoke problem. Will it "clunk" if you kill it in gear or in neutral? Might look into other things. Can you tell where the sound comes from? Maybe the instrument cluster?
Yes, sort of like when you put it in reverse when parked on a slight grade. You can feel it when it does it. I have my foot on the brake pedal the whole time as well, not sure if that matters. But the clunk only happens when I turn the truck off, not when I put it into park.
Have somebody shut your truck off while your outside listening and looking for the sound. With your additional info it could be the slip yoke. Although, I'd expect it to manifest itself at other times as well. I'd try to reproduce under different conditions.
What if you release the brake and then shut it off?
Try applying your e-brake before you put it in park. it might take the pressure off the drive line so there is no slack. see what happens then. just a though. It could be play in the u joints or the rear diff.
you should also tone down your sig pic a little. try this one.
Hi guys, this morning when I got to work I pulled into a parking spot, and then shifted into park, then took my foot off the brake pedal and then shut the truck off. It didn't do the clunk. Does this mean I shouldn't be turning it off without taking my foot off the brakes first, or does that matter?
Listen closely on the INSIDE of your truck down near the HVAC ducts and housing
on the passenger side when you shut it off. My blend door sometimes changes position
and clunks when you shut the truck off esp if your using the a/c in the recirc. mode.
You can actually feel it and its sorta loud too! I also thought it was drivetrain related.
I have a 07 gmt-900
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
