Hello From Canada
RolandS
Hello from Canada!
I'm checking out this webside since a few month and decided finally to become a member today.
I immigrated with my family last Nov. 09 from Germany to Canada. First thing I bougth was a REAL auto, a truck last Dec. 09.
Would like to do some mods (e.g. level, lift, new grill) in the future and am sure to find some help and answers to my question here. :cheers:
2010 GMC Sierra Crew Cap
