Acceleration Noise
i have an 04 gmc extended cab with 106,000 km
some days while driving from cold start it seems(because i don't travel far), that there seems to be a squeal of sorts coming from the motor or area. it only does it when i accelerate. i thought i checked everything but can't find anything.
any ideas
thank you
Sounds like the serpentine belt.
+1
Check your tensioners and pulley bearings also
Does it ever make the noise sitting still in the driveway, engine running and accelerating it? Start by ruling things out one by one.
but when driving, it sounds like motor or tran maybe, just guessing!
Is it a "whine" or a "squeal"?
Whine usually means something bad in the tranny land. Squeal sounds like a belt or bearing on the engine assessories.
Is he talking about the power steering whine or ring these trucks are known for. Some people can't even hear it. kinda like the mosquito ring tone.
it doen't make a noise in the driveway, it does it when accelerating at first until i let off the gas and stops after a few seconds or until i press the throttle again.
it is the original belt i think, i bought it a year ago.
it almost sounds like the power steering noise but it seems fine.
it doesn't always do it and this is what i can't understand.
thank you
I have an '01 Chevy Ext. Cab with the same problem. Turns out it was a bad u-joint in the drive shaft. Would not make the sound while in park, nor in neutral. Only under acceleration when there was a "bind" on the joint itself. Hope you got yours fixed. Let us know what the cause was for your truck, if it was different than mine.
any ideas
thank you
