Anyone Put The 8.1 On A Dyno
I was just wondering what the BIG BLOCK puts down. My truck is a suburban LT 2500 and every week the scale at the dump consistently tells me the truck weighs about 7300 lbs. empty with about a 1/2 tank of gas. This is my first experience with a V8 and i thought the big block would be the shit but am very disappointed. I know the weight might be the issue but i can't Even break the rear tires loose. I thought the monster torque would do something other than when it's raining or wet outside. Am i really getting 455 ft. lbs from the factory? I read somewhere idling it makes 220 ft. lbs. is that true? Will a custom tune really make a difference? I think i want to go back to my turbo 4 in the EVO. At least i can pin my daughters to the seat and hold them there in 4 of the 5 gears.
you have a big ass truck it will not be fast!... its never gonna be anything like an evo ... its meant for pulling really heavy shit. you should try and mod it with an exhaust, filter and tune and you might be happier.
i think a trailblazer ss might be up your alley.
agreed... Make it breath better first with a full intake , then get that air out with duals, and utilize it all with a tune. Then you will be happier..
If not, hook up a chain between the evo and your truck and that will make you happy :thumbs:
lol you dont need duals but and personally i think its not the way to go. A tune will give you more power, and make the truck much nicer to drive. Not saying that freeing up the airflow with some sort of intake and exahaust is a bad idea, BUT the tune will be much more effective. Theoretically all three would be your best bet, just have the truck tuned for the intake/exhaust combo.
It will make the truck much more enjoyable to drive all around thats for sure. Do you really need to be "pinning your daughters to the back of the seat in 4 of the 5 gears?" Maybe one or two gears but driving your daughters aroudn at 120mph? lol i duno.
I don't want to go fast did you see what it weighs Even though i think it has really good brakes i wouldn't get the speed governor removed when or if i get a custom tune. If I want to go fast I'll take EVO and leave the kids home. I just want to piss the wife off with some tire smoke every now and then and light em up on demand for my daughter. Bottom line i just want to play with my truck and i do use it to tow heavy shit every time i break the EVO it rides back to the shop on the back of the truck and when i need to deliver and install custom cabinets the truck pays for itself (I really bought the truck for the cabinets) I looked for that truck for over 8 months it's my dream truck but it would be a wet dream if i could play around with it
120-? in 4th i'm about 155 heading fast to the top speed of 177 (want to go for a ride)
I have been in plenty of fast cars ones that i actually feel safe at 170+ !!
I didnt realize that evos were geared so tall. I dont believe that i have rode in one now that i think about it, but i was comparing it o STIs i dont think they will do 155 in 4th gear. More like a top speed of about 160ish.
I just did a quick google search and its that posted topspeeds for lancers are 150-157?? I guess that must be electronically limited not by gearing? So your saying that if you car had a the stock speed govenor that you woulda been able to hit it in 4th gear?
EDIT: i just did a quick search seems there are plenty of guys going thru the traps @ rev limiter (raised) in 4th gear hitting 120-125 MPH which was pretty much my guess.
Here is a dyno sheet from an 03 8.1 tuned here on our dyno. This is the same 87 octane tune available to anyone who purchases a Predator for their truck.
Pretty stout gains!
Mike help me understand the dynograph. Which A:F line is the tune and which is the stock? How can one possibly be that flat?
Pretty stout gains!
Pretty stout gains!
Great question.
The stock 8.1 cal does not let it go into PE for 30 full seconds, meaning you have to stay WOT for 30 seconds before it will add power enrichment (fueling) to make power. It stays at 14.7:1 even at WOT, thus the HUGE torque gains (40+ ft/lbs) you see across the board.
The 8.1 is begging for a good tune.
Ok so let me see if i got this straight, because I have never tuned any of these trucks or any GM only different makes.
By the graph, your saying that it needs more fuel to make more power, and you find that it makes the best power somewhere in the 12.x:1 range (i cant see the graph right now while im replying). So you make this power by #1 eliminating the 30second delay on the power enrichment, and then richen up the fuel cells, and most likely do some work with the timing as well.
Of the thing to run 14.7:1 full throttle it must really be a pretty detuned motor, like low compression, conservative timing settings? (if you cant tell i dont even know the specs of these monsters). But now I can see why they can make tremendous power naturally aspirated with some headwork, cams and high compression pistons.
Yes, you've got it figured out.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
