Door Handle Question
I'm pretty certain that they will work, but wanted to double check before I committed to buying them...door handles that fit a 2007-2010 Tahoe will work on a 2010 GMC, correct? Like I said, I'm pretty sure they will interchange, but wanted to make doubly sure.
Front doors are the same for sure. You can also swap rear door handles with fronts if you change the screw on arms.
