Humor: Have You Seen.......
relyt1828
:):lol:
Have you seen this person?
Subject is wanted for questioning in case of website profile and signature information misrepresentation. Furthermore, subject is also under investigation for attempting to pull the wool over other peoples eyes, but failing. :lol:
Description:
White male....
Age: 18 or 28
Known hangouts: The internet.
Has been missing about 7 weeks, but has recently been spotted.
If you have seen this subject or had contact with this subject, please contact the Internet Police Department immediately at BR-549.
Enjoy the humor!
:lol:
This is a good-natured ribbing.
Hahaha who are you on TMC? Yeah, I've seen him around. That pic is pretty old though. Damn. But, yeah, the story of TMC, good times, met some good people too. So.......let the questions fly, I don't mind answering them. :)
Wait, that's you txab1. Haha, you created another user name. :lol: And, oh yeah, I succeeded at pulling wool over ones eyes until I finally came clean, then the big scary clown looked down on me and kicked me out. :)
Yes I did.
And you didn't have nearly as many people "fooled" over there as you though you did.
It won't be long till he is banned from here too... :lol:
It still seems he hasn't learned his lesson and still does not like telling the truth! :)
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
