Cruze Rated 42 Mpg Hwy
chevys
This is fantastic. It make the pitiful 40MPG Fiesta even more obsolete than it already is.
But but but..... doesnt it have one of those unreliable expensive turbo motors that wont last and be expensive to fix like Ford....
Or is that a double standard that only applies to Ford. Welcome to the 21st century where turbo engines will become more and more common. Kudos to GM for getting such good mpg. I was actually surprised to be honest how good it was. Its not worth the extra price imo over the regular Cruze though. It does make a marketing statement if Gm can figure out how to market it.
Its a nice car, but I looked at some at a dealer and the sheet metal is paper thin. IMO its not worh as much as they want for it. Nice looking car though.
Its a nice car, but I looked at some at a dealer and the sheet metal is paper thin. IMO its not worth as much as they want for it. Nice looking car though.
I'd say get used to it. It will become more and more common place.
How is any of the relevant to the Cruze getting better mileage than the tin-can Fiesta.
I STILL believe that a high-strung smaller engine is a far worse choice than a n/a, bigger engine that just loafs along creating tons of power with less stress on the engine.
That being said, I trust GMs turbo engines a hell of a lot more than Ford's as GM has proven their engines over and over again. But to assert that you need a high-strung little hampster of an engine to get good mileage is absurd. The Audi A8 AWD gets BETTER mileage than the mediocre Ford Taurus SHOW/Lincoln MKTaurus...and that Audi has a more powerful, proper V8 engine. The new Hyundai Genesis will have a 420+HP 5.0 V8 and it too gets better mileage than a mediocre Taurus SHOW/Lincoln MKTaurus.
So...why, again, are you shilling for Ford and their V6 engines that get WORSE mileage than more powerful V8s?
I have to agree here.
I've actually seen a few on the road here and they look pretty good!
I've always been a Honda guy when it comes to small cars (really like their motors and components), but I'll have to check this Cruze out closer. Looks pretty good!
Yep I agree.
We left no stone unturned or piece of sheet metal un-weighed,”
Great. It's getting even thinner.
I can't believe they would even advertise that. I can see the bill boards now:
Cruise. Now with paper thin sheet metal for better fuel economy. Thinner than Mary Kate Olsen's anorexic tummy.
Ugghhh...that pic's enough to make me sick. And i'm including it in my quote so everyone has the pleasure of seeing it again... :lol:
does anybody else think its funny that this is a thread about drooling over MPG on a TRUCK forum lol...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
