Hid Install Help
I have a 2005 GMC Sierra an I bought a HID kit for the low beams its simple plug and play so they said... When i plug everything up it doesnt work. The only time they do turn on is when I hold the high beams on as in pulling the lever toward me but they dont when you push the lever back to keep the high beam on (their plugged into the low beam but only work on highs!?). Many people have told me i dont need a relay harness for this truck. Ive tried pulling the DRL fuse an nothing. Basically when i put the factory lights back in everything works normal again when hids are plugged in to the low beams the low beams only work when you hold the high beam lever forward. How and what do I need to do to install these and make it work because im really lost on why its working like this.
try flipping the wires sounds like they could be backwards ive had this happen before
i already reversed the polarity thats how i got them to work the way i did
sounds like you will need to run a relay.... might not be getting enough power, could also be a bad ground in that circuit...
