Aoem-gm1416 Question
I have read about 20 threads :D about the remote wire issue with these new trucks. Will the remote wire pigtail on the PAC-AOEM-GM1416 work correctly meaning turn on and turn OFF when I shut the truck off and open the door? :help:
Ok so here is what I have found. This remote wire will work as 12v switch power. But it will stay on for 15 min after the vehicle goes to sleep and will come back on when you hit the unlock button. Also IF you want to change you source for remote there is a BROWN wire on the ignition switch that you can tap into WITH A DIODE. Hope this helps the next guy.
Yea I had to change to a different remote option because that one was causing a severe turn-on/off pop in the speakers. I went with a pin on the dash right side junction box. no more popping. :D
Yea I had to change to a different remote option because that one was causing a severe turn-on/off pop in the speakers. I went with a pin on the dash right side junction box. no more popping. :lol:
Can you explain a lil more please. On the other 12v switched part? Location and or pix?
what kind of amp did you use ?
My set up is one 10" P3 shallow mount 2 ohm, subthump stealth box 10" and a punch p3001 mono amp.
Open the right frt door and on that side of the dash is a panel.Behind it are some junction connectors one of the pins SEEMS 12v switched. It too is timed but different than the radio. I dont know where it comes from but it works for me and I haven't had any issues with it. I wouldn't put anything that has a high draw on it though. I have it running to a Cleansweep that turns on my EQS and both of my amps. There is a post somewhere here with pics of the panel and pin on it.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
