Wax/sealant On A New Truck?
Ok guys, having owned a used black truck, I'm constantly washing and waxing this thing to keep it looking top notch and it has scratches and chips that I have no clue where they came from, and to be honest it bothers me! So now that I'm finally ready to buy a new vehicle, I'm going to stay away from black for a truck.
I'm most likely getting a Blue Granite truck, hopefully it won't be the pain that the black truck is to keep looking new!
Anyways, I'm looking for advice on what to do to it first to ensure a proper start to its life for its paint quality. I've heard not to wax new vehicles, but these things are heat treated from the factory, so I think it'd probably be ok?
I've heard awesome things about race glaze (which is a sealant I believe?), so I was thinking about throwing a coat of that on there and then another coat or two of wax to start things off. Any other suggestions on other brands?
My favorite color is the taupe, with the blue granite in a close second, but I'm afraid the taupe will be almost as bad as black. So I'm going with blue granite haha.
Any advice or opinions? Thanks in advance.
The truck does have a scuff on the passenger rear quarter panel, I work for the dealership, and most likely a golf cart got into the side slightly or something, the dealer is sending the truck to the body shop either way tomorrow whether I take that truck or not.
Well, you can wax a new vehicle without issue. Taupe gray is basically the same as Storm gray. They are alot different than a black truck. It's no where near the same. It has a metallic fleck that hides alot.
Thats the problem with black... Looks beautiful all shined up and with its swirled it looks horrible.. I strictly use Meguiar's products on my black truck.. I use a clay bar to remove bonded contaminants, then I will use a Finishing compound to with a high speed buffer that actually levels the clear coat around the paint, following compounding I use a pure polish to add more gloss, then finally seal with a synthetic sealant.
Polish/Glaze is the same thing. Feeds the paint with oils it loses through oxidation, but since clear coats there is not really oxidation anymore like the single stage paints are.
Wax/Sealant is either a carnauba based or a synthetic based. Winter I use a sealant for better protection against the salt, and in the summer I use a carnauba based for the looks.
Hope that helps,
Nick
That is a myth. It is perfectly fine to wax a new vehicle. Now if you have a freshly painted car done at a bodyshop you want to wait 30-90 days.
Check out the forums at www.autogeek.net. This will probably overwhelm you but there is a ton of help.
I use DP poli Sealant on my truck topped with PoorBoys Natty paste wax.
First thing I would do is make sure the dealer doesn't wash the new truck. The dealer usually uses cheap, dirty rags and towels which causes swirls and scratches.
Wash the truck using the 2 bucket method with grit guards. Wash the top above the door trim first then was below the trim. DO NOT use the wash cloth, pad, etc above the door trim after you have used it on the bottom. Invest in some quality microfiber towels don't use the cheap China made towels they will scratch and swirl the paint.
Wash, Clay bar the truck, then wash again, put a coat of polish/sealant, then wax.
Check out Adams to read about Proper Car Car.
I use Adams products as well. A lot of it has to do with the way you prep the truck during washing, like Brad519 stated...
Thanks for all the replies! I'll start with a good thorough clay bar, then a good sealant, and then a coat of wax or two..
Also, I'm having line-x installed in the bed and on my toolbox, should I wait to wash the truck for any period of time for the line-x to cure? I guess I could ask them when they do it, but I figured I'd add a little to the post.
Signed papers on the Blue Granite, and will be picking it up this week, apparently one of our "salesmen" hit the passenger side quarter panel with a golf cart, and left some minor scratches in it, its nothing serious. But I told them I wanted it sent to the body shop on their dime and fixed right before I would take delivery. Its super minor and would likely buff out, but this is my first brand new truck, and I want it perfect to start out.
I'll have to get some pics of it and the Dmax up.
    Artemis
    Artemis
  • Who's Online   5 Members, 1 Anonymous, 908 Guests (See full list)
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
    • About 8 months after an alignment job by the dealer I started experiencing a pretty significant clunk in the front end on hard left hand turns usually parking lot speeds almost at lock.  Occasionally get the same on hard rights too.   Discovered that the lower control arm attachment bolts are TTY and only to be used for a single use. And then I found some evidence of a TSB that indicates you can over torque those fasteners to about 130 foot pounds.   Asked a local shop to investigate and they found 3 out of four bolts loose and retorqued.   I've ordered the MOOG    K100421 lower control arm bolt kit that is completely reusable and not TTY.    Is the 80 ft pounds a realistic number?  Anyone have experience with those bolts?
    • subscribe to alldata.com, that will have gm's brake bleeding procedure.  and what you have to do likely varies, as if you just replaced a caliper and the MC didn't go dry, you most likely can just do a normal bleed on that corner, but if you disconnected lines at the MC or the abs unit, or let the MC run dry while doing work, you'll have to do a more extensive/complicated bleeding procedure.
