Oil And Coolant Mixing.. 2004 5.3l Silverado
JRD761
I've got a 2004 Silverado 1500 with the 5.3L V8 engine and around 85,000 miles.
I've noticed over the past couple weeks that my coolant level keeps getting low.
I'll top it off, then in a couple days, it's back to where it was.
I don't notice it leaking anywhere. There are no drips in my driveway, I don't smell burning coolant, and I don't notice anything leaking from anywhere.
Today I checked it out a little better. I pulled off my oil filler cap, and in the plastic tube that comes from the valve cover to the oil filler cap there is a bit of cream colored sludge.
I changed my oil around 2,000 miles ago and none sludge of this was there...
I checked the oil level on the dip stick and it looked fine.. the oil didn't look dis-colored or anything, and the level is just fine.
I started up and couldn't tell if its smoking or not.. it's pretty cold out here and all cars tend to let off a little steam or something that looks like white smoke when its cold, so I can't really tell if it is smoking or not.
The truck does not overheat at all.. just sits at it's normal temperature and never goes over or under it.
First question: What do you guys think the posibilities could be? Head gasket? cracked head? something worse?
That is what is in the oil filler tube. I haven't gone further into the motor to see if there is anything elsewhere.
Second question: I saw a TSB about Castech heads having a tendency to crack on these trucks. If this is my problem, would my truck (a 2004 at 85,000 miles), be covered under some type of warranty extension because of this TSB? Or is Chevy not covering anything at all?
if it castec heads, you are sol and will have to fork out your own money for the repair
I just replaced the water pump gasket last month because those were noticeably leaking.. was getting a puddle in my driveway, could smell hot coolant.. and was loosing coolant very fast.
I replaced it (and I made sure the coolant system was filled properly and all the air-pockets were removed) and that's when this all started.. but I'm not getting any leaks. There has been nothing on my driveway at all, nothing in the parking spots where I park it, and I don't smell the hot coolant thing anymore...
But my thing is, if I take it to the dealer, will they even do anything? I'm very strapped for cash right now (was laid off a couple months ago and haven't been able to find work) and can't afford anything right now. If the dealer will fix it for free then great.. but otherwise it's gonna have to sit until I get a job.
I took off the passenger side valve cover gasket today, and all appeared normal except for where one of the pockets where the head bolt is at in the middle of the head is filled with a milky/creamy color fluid.. the oil and coolant combination.. all the other pockets had oil in it which I am pretty sure is normal, but this one pocket is full of it kind of like the service bulletin about this problem said..
So, next question: Do you think if I grind that down slightly and apply JB Weld (for the right kind of metal.. are these heads aluminum or cast iron or what?) and would that fix it?
Or should I just get new heads?
Update:
I took the valve cover off again and took some pictures this time.
(the green circle is the area where the weird colored oil was. There was still a good amount there, where the arrow is at)
Here are some other pictures.. maybe you guys can see anything wrong or abnormal or can tell if I even have the heads the Service Bulletin is talking about..
I rented a coolant pressure tester from Auto Zone and put it on my truck.. pumped it up to 15psi, and let it sit for around 10 minutes.. it did not loose pressure and I did not notice any leaks or anything abnormal.
So I really don't understand where I'm loosing this coolant from.. (I may have over exaggerated on a post a little big ago.. I've probably lost about 1/4 of a gallon in the past couple weeks.)
To identify suspect heads you have to follow the TSB to find the castech logo. The location you show is where the leaks shows.
Don't JB weld it's not going to help you. Don't use stop leak, it does more harm then good.
IMO you are over thinking this. It looks to me like you have a little moisture mixed in there but moisture is not necessarily coolant. This is pretty normal, especialy if you are in a cold environment.
How do you know for sure you got all the air-pockets out? How did you bleed it? If you didn't use an air-lift or something similar then there is really no way to know. I would drive it and monitor the coolant and oil and see what happens. Even if it was coolant, that little trace you see wouldn't cause any issues (I still don't think it's coolant).
If you drive short distances, combustion products contain water and would be normal. Not great but no problem either. Is your coolant level decreasing? Is you oil level rising? My old vw beetle did this horribly and it did not own a radiator.
Ken
Most likely you have the dreaded Castech problem. If so your heads will need to be replaced. My truck is a 2004 with a 5.3 with 114,000 on the odometer. This fall I noticed coolant loss, no leak, lifter noise on start up, and a weird temp problem every now and again. Did a search on this handy dandy board and found about the Castech problem.
Removed valve covers, passenger side looked ok, started to worry a bit. Worried that I pulled all that stuff off for no reason. I pulled the driver's side. The driver's side was full of the Dexcool/Mobil 1 sludge. Removed both heads and I took them to a machine shop to have pressure checked. Both heads failed. The machine shop ordered two new GM bare heads and is transfering old valves & valve springs to new heads. Valves are being reground to spec, replaced where necessary, springs tested and replaced as necessary. All new guides and seals installed. Cost $780.00 + valve grind kit.
I'm doing the installation myself and should have the truck back on the road in late January. I'm overseas until then. New heads will be waiting for me when I get home. Before I put it back together I'm going to replace the water pump just not to have to tear it all apart in the near future. It will also get new lifters, plugs, wires, belt, & hoses. I figure all the parts should come in for around $1,200.00. I have done some research, some dealers want around $4k for this repair.
No amount of JB weld, or stop leak will fix your problem. Only a new set of heads will solve your problem. If you have the Dexcool sludge, then you need to get the heads pressure checked to determine if they are toast. If I did not have the ability to do this myself I would have put it back together and sold the truck.
I just replaced the cracked Castech heads on my 2004 Sierra. The drivers side head was cracked and the valve cover had a creamy coating of oil/coolant. The crack was toward the front of the head. I'm wondering if the crack on others is from the drivers side head? The oil wasn't black like it should have been. It looked close to a fresh oil change. No milky look to the oil at all, but it did have a slight coolant smell. Lifter noise on startup. Puff of smoke also on startup.
After replacing the heads the truck started getting a P0327 and P0332 knock sensor code. I cleared it three times. Yesterday I unplugged the harness and plugged it back in (it appeared plugged firmly in) and cleared the code again. Drove the truck about 30 miles and no code has popped back up. But if you replace the heads, you might want to replace the knock sensors also since everything will be torn apart anyway.
I've been a GM person for quite a few years, but this truck may change that. So far I've had the transmission rebuilt, gauges repaired, heads replaced and soon to replace the ISS.
Update:
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
