Ful Pressure Regulator
Where is the fuel pressure regulator located on a 2002 4.3L V6? Its not on the drivers side where it is on the V8s/
Fuel Pressure Regulator Replacement (4.3L (RPO LU3) Engine)
Removal Procedure
Remove the upper intake manifold. Refer to Upper Intake Manifold Replacement in Engine Mechanical-4.3L.
Remove the fuel pressure regulator retainer clip (5).
Twist and pull the fuel pressure regulator (6) in order to remove the regulator from the housing using a shop towel to catch any spilled fuel.
Remove and discard the regulator seal O-ring (10).
Remove and discard the regulator filter (9).
Remove and discard the regulator seal O-ring (8).
Remove and discard the backup ring (7).
Cover the fuel pressure regulator housing to prevent contamination from entering the fuel system.
