Wrong Waterpump?
restricted
Have a 1998 k3500 7.4 . Water pump went out, replaced it, overheated within 15min, replaced thermostat but didn't help. I took new water pump off and took plate off back of new and old to compare propellers , they were opposite, so took it back bought another, before i put it on took back off to make sure propellers were same, they were so i installed the new one. Overheated in 15min again, I know there is not an air lock . I do see that there is a heavy duty water pump available , wondering if I need to try this or there is something I am missing.
Thanks
Restricted
How do you know it's not air locked? Water pumps are simple. Maybe time to look at the radiator?
Mark
I have loosened all the hoses , flushed it did the whole cap off thing. It didnt start overheating till i replaced the water pump, only reason i had to replace water pump is because it was leaking around front seal, it still kept it cool and never overheated.
I'd say the t-stat isn't opening. Either it's bad or air locked in frt of it and won't get hot enough to open. Try drilling a 1/16" hole in the stat to let it vent.
Mark
Mark
This is the 2cnd t-stat i have tried, but i will try the hole. Thanks
fill it up with the t stat out ,when its full at the t stat ,put on a new one,continue filling,--done, no air at all
most t stats have a little vent dont they??
Just put one in an s-10 that didn't. Ive seen em both ways.
Mark
It still sounds like there's air in it. Try taking the t-stat out and see what happens.
Mark
Did, wont get over 110.
This proves that it's NOT the pump. Sounds like a thermostat problem.
This might sound stupid and people often do this, are you sure you put the thermostat right you can put them in upside down.
Its in the correct way. But dont see how it could be the therm when it was fine before i changed the water pump. Didnt no if the heavy duty water pump moved more capacity or was just built heavier.
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 981 Guests (See full list)
