Is There A 6" Suspension Lift That Doesnt Require Cutting Or Weld
I tried do some research but seems like all the kits involve welding or cutting. I can weld just dont want to make the lift permanent or just dont like the idea of welding on a new truck. I understand the get what you pay for deal and would be all ready to jump on the BDS kit its just hard to believe there isnt a kit that doesnt involve welding and such.
Thanks for any input
there is NO kid that doesnt require cutting. the crossmember that runs between the rear lower control arms is in the way of dropping down the differential. if you make a clean cut. save all the pieces. theres no reason it cant be returned to stock if you can weld. bds makes a very nice kit because it keeps the tortion bars in the stock location so you dont have that ungodly crossmember hanging down. but you wont find a kit at all that doesnt require cutting and welding. sorry
@ John :
that is not true...there is a liftkit that doesn´t require cutting or welding..it´s the 3" RC liftkit but as we all know, nobody who had it here on this forum liked it a lot.
Had to edit my post, Justin has a 2500HD so the 3" RC kit is useless for him (only the 1500s).
@ John :
I believe he's looking at a 6" lift not a 3" ................... just sayin.....
thanks for the replies. sucks to hear they dont make one but oh well.
Trucks not new anymore its an 08!!! I had my 08 cut up a long time ago and its still holding up just great with 50K on it. (40K of it which was lifted). Just do it you wont regret it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
