Bluetooth Issue
Ok, so my phone just started having an issue today. Normally when I turn off my truck the truck's bluetooth will disconnect from my phone. Well I just noticed this morning that it isnt. I got a call on my cell phone earlier and noticed that when i answered I couldnt hear anything on the phone, so I looked at it it was saying that it was still connected to the truck. I turned off the bluetooth on my phone and called back. and then turned on me bluetooth and as soon as I did it reconnected to the truck, which is off and locked. WTF? I wont remember to turn off my bluetootheverytime I get out of my truck and after trying numerous settings in my phone and the truck I still cant seem to resolve the problem.
Anyone else have this issue or know how to fix it?
BTW: phone is a Motorola Droid if it makes a difference.
Thanks
No one has any ideas? Still havent come up with any reasons why it just started it. Haven't changed any settings or any thing recently enough to trigger this.
No issue for me, it's been working flawless. I use both an ear piece and the truck. Both work smooth :sigh:
Thanks
The only reason I can think of would be that the power is not being turned off when you open the drivers door after shutting the truck off. Does the radio stop when you open the door? Once you get about 30 feet away it will disconnect as well. Mine disconnects as soon as I open the drivers door with the engine off.
Thanks
mine does as described above...
op may have a driver's door switch possibly failing.
Radio still turns off as normal, but the bluetooth still stays on. I'm gonna watch it when I go into work in the am and see how far I get before it disconnects, because I've tried walking to the opposite side of my house and it still stays connected.
That sounds like suspicously far for a Bluetooth signal to travel. How many feet away would you estimate you were and it stayed connected?
Class 1 Bluetooth spec ranges as far as @300 feet, Class 2 is I think around 32 feet, and Class 3 is real short, like 3 feet. I am only assuming here, but I would think that the truck transceiver is at most Class 2 and more likely Class 1.
Could it be possible you are actually paired/linked to another bluetooth device in your home? Does the Android device show the ID of what you are linked to?
I would bet that when this happens the green lights on your mirror are still on. They should shut off when you open the door. I have had this happen before, when it is not shutting off remove the dash panel and unplug the VCIM for a few minutes then plug it back in. That should reset the module and you will not have any more problems.
I have a range of about 50-60ft. and yes I just looked and the mirror lights are still on. So how do i reset the VCIM, and will that hurt anything else in the truck by doing that?
Not sure on an LTZ, but on my 09 LT Extended cab, the VCIM is not too hard to get to. It is behind the large trim piece that is under the climate controls. It is mounted at a bit of an angle and would not be too hard to unplug and reset it once the trim piece came off. As I recall, to remove the trim piece took a socket and philips screw driver.
Anyone know if pulling the fuse for the module would work as well?
I looked up what fuse this might be in the information I have:
49 INFOTMNT Fuse 15A
Video Display (U42), Rear Video Display
(DNU), Vehicle Communication Interface
Module (VCIM) (UE1)
This fuse is in the underhood fuse box.
Even if pulling the fuse for or unplugging/pluggin the module, it still needs to be known what caused this. I have some literature that explains OnStar and it mentions the green LED can come on to indicate a message. Thats what I think caused mine to stay on one time, Onstar left a message wanting me to renew. I thanked them for the dead battery and told em' never to call again.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 1 Anonymous, 579 Guests (See full list)
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
