Using Auto Mode In Town
The local dealership service guy told me never to use Auto(4x4) in town that it will mess things up.
I just said ok and turned it back on. I think the guy is full of BS. Am I wrong?
Why didn't you ask him to explaing it to you since he's so smart and goes around telling people that ?
Next time you're at the dealer with a question, push on past the "service writers" in the receiving bay and talk directly to the guys in back. It's been my experience that the guys at the computers know more about their computers than they do the vehicle your bringing in for service or repairs.
Nothing in the owner's manual about the transfer case says Auto mode can't be used in town. It works much better in tighter turns than 4Hi anyways.
Auto 4 in the city is fine, I only use it in Rain and Snow, and leave it in 2WD otherwise because I have noticed as much a 2mpg difference using it.. but having it in Auto 4 is not going to hurt anything.. Auto 4 is like a simplistic AWD system to assist you in slick and slippery road conditions without having the 4hi always engaged, the Auto 4 only engages if the computer senses wheel slip.
my owners manual doesn't say anything about AUTO not being used in town.
here is what is says specifically:
AUTO (Automatic Four-Wheel Drive) : This setting is
ideal for use when road surface traction conditions are
variable. When driving your vehicle in AUTO, the front
axle is engaged, but the vehicle's power is primarily
sent to the rear wheels. When the vehicle's software
determines a need for more traction, the system will
transfer more power to the front wheels. Driving in this
mode results in slightly lower fuel economy than
Two-Wheel Drive High.
the specific DO NOT USE statement is with regards to 4hi and 4lo:
Notice: Driving on clean, dry pavement in
Four-Wheel-Drive High or Four-Wheel-Drive Low for
an extended period of time may cause premature
wear on your vehicle's powertrain. Do not drive on
clean, dry pavement in Four-Wheel-Drive High or
Four-Wheel-Drive Low for extended periods of time.
Auto-4wd is just that... "automatic". The only "harm" will be a decrease in mpg (about 1 mpg).
I use auto when the roads are snow covered and I like it better than 4H....Mileage goes down...on mine well over 2mpg...close to 3
Is there a maximum speed you should stay below in 4hi when driving in snow. Besides the safety factor of course. I was just wondering if higher speeds in 4hi can be detrimental. We got some snow down here in the south, and my 4wd driving is usually hunting related and for short periods of time.
The problem with 4-hi (or 4-low for that matter) is the lack of a center differential. Thus when making a turn the front tires are forced to spin at the same rate as the rear (or travel the same distance). If you can picture a turn you know that tire rear tires do not follow the same path as the front and thus do not travel the same distance. On a good traction surface this causes binding and in extreme cases can lead to actually breaking something.
4-auto on the other hand adds a center differential the equation. This allows the front and rear to turn at different rates and can be used on any surface, wet, dry, slippery or not.
As to speed, it does not play into this equation.
    Kirk Belch
    Kirk Belch
  • Who's Online   3 Members, 1 Anonymous, 1,215 Guests (See full list)
