275/55/20 Or 305/50/20 Tire
martens
I've got some 20 inch x 8.5 inch wheels coming for my 95 GMC. I have decided on Cooper Zeon tires.
I can't decide between 275/55/20 or 305/50/20. With my cars I have always been pleased with a bigger tire. Being new to trucks, what is the pros and cons of the bigger rubber.
I've checked and should have plenty of clearance.
Right now the truck gets good gas mileage and rides well. I can't imagine the wider tire riding any different as they both have the same sidewall. On my car, the wider rubber does track road ruts at times and I would imagine the same would apply to a truck.
I don't plan to get crazy off road but would like to be able to do some easy trails.
Either tire size would work for what you want but the 305's def. will look meatier. I'm currently running the 275/55's and in the spring will get the 305's.
I have the 275/60/20 on my truck with 20x9 wheels. If I was doing it over I think I would go with the 305/50/20. I think the 305/50/20 may be a touch shorter in height but I am not sure. I know the Cooper tire site has details on all the measurments if you look at the bottom right corner of the screen on each tire you select there should be an option to view a detailed measurment chart.
So far I have been pleased with the Cooper tire. I have 15,800 miles approx on them and they are about 50% worn for me. I am not easy on them. For the price they have been a good tire. Previously I ran BFG tires and for the price these are a good option.
I have the 305 50 20s on my truck and they are a nice setup.
Do not track in any road grooves and per the cooper site the sidewall is actually a little taller than the 275 55 20s
I would choose the same tires again.
I would get the 305s
Size 275/55R20 117S XL
Product Code 01405
Service Desc. (Load Range) 117S
UTQG Rating 520 A B
Approved Rim Widths (in.) 7.5 - 9.5
Measured Rim Width (in.) 8.5
Overall Diameter (in.) 31.9
Tread Width (in.) 9.3
Tread Depth (in.) 0.44
Max Load (lbs.) 2833@50psi
Tire Weight (lbs.) 47
Size 275/60R20 119S XL
Product Code 01403
Service Desc. (Load Range) 119S
UTQG Rating 520 A B
Measured Rim Width (in.) 8.0
Overall Diameter (in.) 33.0
Tread Width (in.) 9.0
Max Load (lbs.) 2998@50psi
Tire Weight (lbs.) 53
Size 305/50R20 120S XL
Product Code 01407
Service Desc. (Load Range) 120S
UTQG Rating 520 A B
Approved Rim Widths (in.) 8.5 - 11.0
Measured Rim Width (in.) 9.5
Overall Diameter (in.) 32.2
Tread Width (in.) 10.4
Max Load (lbs.) 3086@50psi
Tire Weight (lbs.) 54
305s will look a little too wide for the wheel on an 8.5 inch wheel. With the zeons, that might look pretty good. You'd just have to test fit one. I have 275-55s on 20x9s and they fit perfectly.
The 305's should be about .6 inches wider. I've got flares and the wheels are 31 mm off set so they should sit inside the wheel well/flare pretty well.
The wheels should be hear tomorrow and I am going to see if the tire shop will mount up a 305 first. If it doesn't look bulged on the wheel, I think I am going with the 305's.
  • 6 months later...
So how did this work out for you? Will be getting some tires for my truck (oem 20"s) by the end of summer. Was looking at 275/60/20 to get a 33" diameter tire but was curious how the 305/50/20 fit. From NadieLite's post, the 305/50/20 may be .8" shorter which isn't much. Sorry for bringing an older post back up but I've been debating on 305/50/20 or 275/60/20 too. My current 275/55/20 are good but want some more height.
Go with the 305's. After much debate and a lot of time and help from this site I eventually decided on a 20x8.5 XD Spy with 305/50 Cooper Zeon's. It turned out just as I hoped. Thanks again everyone. Sorry for the pics, lots of reflection right after washing.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
