tnerb
Who runs this size tire. I got this size tire in a BFG T/A KO
What offset and backspacing do I need for this for a proper stance/no rubbing.... Can I run them on a stock chevy 20" rim with ease?
Thanks guys
I think 5.7 backspace is what you're looking for. I'm not sure about the stock wheels cause depending on the lift they may not work and might be to narrow for a 325 tire.
Some of the Experts will surely chime in to offer their advice.
Matt aka Blackout07 runs that size tire on a 20x10 wheel but he has a 6" with a 3" body lift and 1" spacer.
I'm betting there will be some trimming that will have to be done to get them to fit without rubbing with the 6" lift.
I will run the 6" with a small spacer to level the truck depending on my front end angles. I will eventually run a 1.5" BL as well.
Whats a stock 20...9" wide ?
I don't think the stock 20's are 9" wide. I want to say 8.5 but I'm not sure.
Someone with some decent knowledge will chime in sooner or later :lol:
Stockers - 20x8.5 with a +31mm offset(5.9" BS).
Depending on the lift, you may be able to run those wheels without a wheel spacer. I ran 325/60's on a 20x8.5 with 5.5" bs and the tires were fine. Obviously a wider wheel would be better for tire wear but you can do it. And you can bet on some trimming to clear those tires. What lift are you going with?
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 3,072 Guests (See full list)
