R.c 2" Level Kit
I was just on the Rough COuntry website, looking at leveling kits for a NNBS... this is what the ad says.... Does anyone know why its not for trucks with the 6.2L???
2007 - 2011 4wd/2wd 1500 Pickup 2" Leveling Suspension
java script:;java script:;Home » Suspension Lifts » Chevy / GMC 4wd » 07-11 1500 Pickup Price: $69.95 - $64.95!Kit Contents: Lower strut mount extensions and hardware. Ships Same Day* Order must be placed by 3:00pm (CST)
and parts ordered must be in stock. Notes: • Does NOT fit models with 6.2L engine. Benefits: • Maintains factory ride quality. • No need to disassemble strut.
:jester: I'm running it without issue.
I know, i saw that you had it on and was hoping you would respond.... I dont know what the difference would be?? Maybe I will see what R.C. has to say about it
The night I drove my truck home, my good friend helped me install it. I had it prior on my 07 without issue and just moved it to the new truck. The only difference I can see is suspension is a little heavier than my 07 was, but the RC block installed without a hitch :jester:
Lol same truck same suspension. Last time i checked the motor has nothing to do with suspension. ;-). They maybe meaning the denali they have 6.2 but they are awd full time making a vibration on front end from axle angles.
Good point, I forgot about the Denali .... That was my thought as well.. whats the size of the engine have to do with anything
Maybe its risky to lift teh front higher because it could lift the wheels when you floor it!! :jester: Liek its been said before: " its a CC Corvette!"
Interesting didnt notice this when I placed my order when they were on sale for $39 :jester:
I sent RC an email tonight, we will see what they have to say. I could have sworn when I ordered mine in Dec there wasnt the note about the 6.2
I have this same 2" RC leveling kit on order.
Does anyone know why the cv axle angles cause a vibration in AWD but not in 4hi? Or does it happen in 4hi as well. My 2011 can select the auto 4wd system or 4hi. I'd like to know what to expect before I install it. I've only used 4hi for snowstorms. Otherwise I drive around all the time in 2hi.
-Steve
I believe the only issues that were fairly hit or miss were on denali's with AWD, which isn't to be confused with the Auto 4WD on the regular trucks. My dad has one on his truck, and there are no issues in 4 hi/low, auto, or 2 wheel
it only dose it at higher speed when u accelerate. I put my truck in 4wd on interstate at 50 and sped up and had a light rumble/vibration. i did it b4 with kit off and it didnt do that. I had a friend on that installed a 2" kit on his denali's full time awd. he put on 2" level kit and had a vibration. So i tried it out what i posted above b4 and after and those were the results. so he took it off and no more vibration. What i said to do is get the diff drop and skid plate from then RC 3" kit. So he did and we installed and no more vibration. So he has a 2" level kit with 3" diff drop and axles look good. he is thinking about going with a 2.5" level kit now
