What Needs To Be Done
I am about to reach 30,000 miles on my truck. When I went to get an oil change I was recommended to do a 30,000 mile tune up for about $420.00.What would you guys recommend that actually needs to be done or is the shop right?
Get a new dealer!
I would look into changing front diff, rear diff and transfer case fluids. Inspect the tranny fluid. Unless you do a lot of towing it should be ok. Just my .02.
Diff and t-case oils exchanged, trans fluid flush, if it has an Allison then it gets a new external trans filter(if needed), D-Max's get a new fuel filter (if needed), both gas/diesel engines get a new air filter (if needed), tire rotation and oil change (if needed), brake inspection with a clean/lube of caliper pins and brake pad contact points, wheel alignment check and general walk around inspection for lights/wipers/belts/hoses/etc.
If it was mine, that's what would be done. To each their own though. I just pulled my transmission down, after 195,000 miles, due to a torque convertor that was lightly howling when cold, and found the inside of the transmission
to look like the inside of a 30,000 mile transmission. Factory original engine, transfer case and diffs also. Just sayin.
Oh I hope you don't fall for thier "semi-annual inspection" they say needs to be done at every 2nd oil change also. :lol:
Luckily I never have but this is my first vehicle to reach the 30,000 miles and that I plan on keeping. I just wanted to make sure that there was nothing to worry about.
Thanks for the replies; I will check what can my self.
A "30,000 mile tune up" should consist of...An oil change.
this + maybe a tire rotation if needed... won't hurt to look at all other fluid levels, but nothing else needs to be changed
